Question about Garden
Primer Button Weedeater Gas BC 24W - The rubber bulb primer button is cracked. How do I get this part holding the rubber bulb apart so I can put the new one in. Can't screw it off or pry it off.
  • 284 Answers
This part is sold as an assembly Part# 530038874
Undo the screws holding the primer and note the fuel line location
as the new one will be identical.
Note the long and short tube connection under the primer bulb itself and the designated tube for each
Posted on Jun 04, 2009
How to replace primer bulb
Shauna, Primer bulb replacement. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Primer Bulb In Line Replacement Weed Eater Toro
HOW TO Replace the Primer Bulb on Weed Whacke
Weedeater Primer Bulb Replacement
Stihl FS55 Primer Bulb Replacement How to Replace Stihl FS45 FS55 FS65...
Jul 28, 2016 | Garden
Why my weedeater idle to high and why air bubble in the primer bulb?
Its not un common to have air in the primer bulb, Check for a possible air leak in the system. This will make the saw idle higher than normal if its sucking air from elsewhere.
May 19, 2016 | Garden
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
How to relace the rubber primer button on a 3 one half hor. tecumseh push mower
it is held in with a snap ring remove the ring then the bulb
Jun 28, 2012 | Garden
How do u put a new plunger on a gas weed eater
Hi dubois karen...
You will remove the carburetor from the weedeater and once you have it removed, you will see four screws holding the carburetor primer bulb in place, remove the screws, remove the old primer bulb and replace with a new one then replace the screws and reinstall the carburetor...your done.
Please take time to rate me
Sep 18, 2011 | Garden
My briggs and stratton 158cc 500series push mower primer button melted from sun. how do i replace it?
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
May 09, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
Featherlite SST 25 Gas Trimmer
Clean the carburetor and replace the spark plug and air filter. Also make sure the oil/ fuel ratio is correct.
Feb 10, 2018 | Poulan WeedEater Hedge Trimmer 25cc Engine
Featherweight weedeater primer bulb repair?
featherweight weedeater - runs rough and has no power
Jul 03, 2009 | Garden
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Garden Logo
474 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
