Question about Jenn-Air 24 in. DW731 Built-in Dishwasher
Washer arm not moving and holes are clear on Frigidaire dishwasher series 650
Same as the other lady--arms not moving and the holes are clear on the arms--what is the problem--everything else appears to be working properly--makes a noise it did not make before
SOURCE: The upper spray arm came off. How to I put it back on?
I realize this problem was in March of 2008 but if in the case someone else needs the solution. The Frigidaire website doesn't list this in there troubleshooting list either.
I had the same problem and let the upper spray arm off for a couple of months. My glasses were not getting cleaned as well so I was rewashing everything by hand. What's the point of that if I have a dishwasher.
On the inner roof of the dishwasher there is a round piece that you hook the upper spray arm to. Well it's a pain to try to just snap it on. Unscrew it by hand, get the little white plastic piece so the teeth are pointing out of the hole and snap on it on that way. One tooth at a time and it should go back on. It will be wobbly. Works like new I am so happy !
From now on be careful what you place on the top rack, if the item is too big it will cause it to snap off again. I know I will :)
Thank god I didn't get a repair man in here for something as minimal as that.
Posted on Nov 27, 2008
  • 311 Answers
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off , can do you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
SOURCE: frigidaire fdb949gf dishwasher won't spray water from arms
I found on my first dishwasher the arm holes were plugged. I had to clean out each and every hole with a small wire. They would not even turn until I cleaned them God luck.
Posted on Jan 31, 2009
  • 59 Answers
SOURCE: Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Posted on Mar 11, 2009
SOURCE: upper spray arm broke off
I hope it did not break, only came off. I had the same problem. You have to unscrew the round part from the ceiling of the dishwasher, put the three pieces together, easy, and then screw the whole thing back. No tools needed. Top rack can stay on while working. It helps if the dishwasher is empty. If the threading is good, this should solve the problem.
Posted on Apr 16, 2009
  • 423 Answers
SOURCE: Frigidaire Dishwasher - Spray Arm Not Working
When a dishwasher has been checked for obstructions in the sump area and the spray arms can spin easily (by hand) plus the spray arm holes are not blocked, you end up with either a broken impeller or a failing wash pump motor.
If you would like more details of have more questions, please post comment back here, OK?
Good Luck!
Posted on Apr 26, 2009
0 characters
1 Points
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Frigidaire dishwasher FDB710. The spray arms seem to stick.
Have you tried cleaning the spray arms?
They are made so that they can be removed by the user for cleaning as it needs to be done occasionally. Look for a big nut and turn it anticlockwise, then check all the holes to make sure that they are clear.
Mar 11, 2012 | Frigidaire Dishwashers
I have a Frigidaire dishwasher model # GLD3450RDS0 and the upper spray arm has come off. I have the arm but it will not go back in place. Am I missing a washer or something to secure the arm? how do I...
You will need to get replacment parts...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Mar 16, 2011 | Frigidaire Professional Series 24 in....
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
My frigidaire ultra quiet spray arm doe's not move.Water trickles out the holes,no pressure.
water does not spray on the top arm until a later cycle...only one arm spins at a time... a fridgidare thing
May 11, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Apparently no water pressure to upper washing arm.
Hi sounds like there is a blockage in the circulation pump which causes low water pressure as it cannot push the water around. You would have to remove the unit and turn on it's side and remove the circulation pump to clear the blockage.
Also check all the holes in your spray arms for any blockages. Best to remove each arm and clean in the sink. Any blockages causes the arms not to turn.
Jan 24, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
Upper spray arm on dishwasher does not move
you most likely have gunk inside the arm or holes not allowing the water to spray out and turn the arm. Otherwise, the arm bearing may be stuck and will need a gentle push to loosen up.
Sep 22, 2009 | Dishwashers
I have a fridgidaire quite 1 built-in dishwasher aprox 10 yrs old . Its not cleaning dishes sounds funny,and soap is staying in dispenser. Have any advice
first check the wash arm ... check the holes in the wash arm . make sure that they are not plugged.
next check that the wash arm is moving . spin it to check that it is free.
next check that there is water pressure to move the wash arm... let me know
Dec 15, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
308 people viewed this question
Top Jenn-Air Dishwashers Experts
Michael Thomas
Michael Thomas
John Tripp
John Tripp
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
