Home | Danby | DDR586R Dehumidifier - 58 Pints Dehumidifier | Tube to floor drain sto...
Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Tube to floor drain stops working and bucket in unit fills up
By imtut46236 on Jun 04, 2009
My dehumidifier has a hose that drains into a floor drain. After some time, it stops draining thru the tube and instead, the water container in the unit fills up with water. What causes this to happen, and how can I fix it. I've cleaned out the tube, as their is a film or mildew(?) that may prevent the water from going through the tube. The tube runs about 10 ft. to the drain. Anything else I can do to make this drain through the tube to the floor drain?
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
