Question about Radio Communications
I need a manual for a MJ270 walkie talkie, I'm trying to figure out ''vox'' & ''ivox'' Can't find my manual
  • 67 Answers
How to cancel "vox" mode
go to setup rotate and than you see vox on or off, like bells of or on.
Apr 27, 2015 | Universal Bellsouth T-388 1.0"" LCD 5KM...
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Vox
In order to use VOX on your radio you will need a VOX capable accessory OR you can use iVOX which allows you to use talk hands free without an accessory. The instruction for both these features can be found on page 22 in the user guide.
You will need to fill in the "dot" with a "." because Fixya is not allowing insertion of links currently: giantintl dot com/ContentManage-new/manuals/Moto/T65xx.pdf
Keep in mind when using VOX the radio will open up its transmitter with any noise, not just exclusively voices. So if you are in a high noise environment you will not be able to use VOX or iVOX.
Best regards.
Jun 21, 2013 | Motorola TalkAbout T6530R (14 Channels)...
We tried using a headset with it. Now, without the headset it goes back and forth between iVox and regular mode everytime you push the PTT button. Is there a way to stop it from going into Vox mode?
Here is a link to the user guide, reference page 22 for instructions on turning iVOX and VOX on or off: http://www.giantintl.com/ContentManage/manuals/Moto/T65xx.pdf (Double check you do not have the lock symbol showing while trying to change programming.)
Also, another phenomenon which can occur is when you unplug a headset or audio device while the radio is still turned on. This can leave the radio partially in VOX mode. You might try plugging in the device with the radio turned off. Then turn the radio on, use the device in VOX mode. Then shut the radio off and remove the device. See if it clears the radio's sense of having a headset plugged in.
A damaged jack can also cause the same problem.
Best regards.
Nov 05, 2010 | Motorola Talkabout T6500 (7 Channels)...
I cant turn the vox off of the radio. i plug in the headset and it locks the keys and i cant hear anyone talking to me through the headset.
Only plug the headset in with the radio turned off, and be certain to use a headset designed for the radio. On the SX model radios the VOX or iVOX feature is automatically set to the last sensitivity setting when you plug in an audio device. Here is a link to the user guide, where you can read how to turn iVOX and/or VOX on or off.
http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Best regards.
Nov 01, 2010 | Motorola SX600R Two Way Radio
Voice activation
The Motorola T-5000R does not have VOX capabilties. Page 23 in the manual explains this.
Here is the Link: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
HiTech Wireless
Mar 18, 2009 | Motorola Walkie Talkie 2-Way Radio
Have no info booklet need to get rid of feed back
To select the VOX level:
1) Enter the Menu. Advance through the Menu until
the vox icon appears on the display. The current
level (OFF, 1-3) will be indicated. Level oF (OFF)
disables VOX, while levels - set the
sensitivity of the VOX circuit.
2) Press either the up arrow or down arrow key to the desired VOX
sensitivity level. Use level 1 for increased
sensitivity to voice in normally quiet
environments, and use a higher level to reduce
undesired activation in very noisy environments.
3) Exit the Menu.
Feb 27, 2009 | Uniden GMR-325/2 2-Way Radio Walkie Talkie...
Configuring audiovox GMRS1072CH walkie talkie
With the issue of 240V if the charger has not a Voltage switch, you will need to find another charger/transformer with the same Voltage/Amps ouput that works with 240V.
For Vox operations, this feature works independly form channel, you should choose the channel# and code # first, to match both radios, and get them communicate, then the Vox feature.
In Some radios the VOX feature works with an external audio accesory, in other radios works with out it.
Basically if this radios works without it, you should see that the radio transmist by itself when you speak direct to the radio, and stops transmiting 1 or2 seconds after you stop talking.
Good Luck.
Nov 20, 2007 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Radio Communications Logo
503 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
