Question about Mackie MR5 MR5 Reference Monitor
Mounting a Makie MR5 on a tripod speaker stand..
How do I attach my Makie MR5 studio monitor to my tripod stand? I am afraid to drill holes in the bottom of the monitor, because I don't want to hit anything important on the inside of the speaker, hence the sub. How much clearance (in inches) would I have to drill on the bottom of an MR5. I'm not going to be playing it that loud, so maybe Velcro applications would work?? Thanks for the help.
  • 73 Answers
Hi there. Search "top hat". There are 2 different depths. Compare measurements to space available in and on the enclosure where you plan to install it. (bottom)
Thanks
Paul
Posted on Jul 11, 2009
Static/popping noise from mackie mr5's
Check the input level. Sounds like the signal is being clipped.
Jul 20, 2013 | Mackie MR5 MR5 Reference Monitor
One speaker stopped playing bass
Sound like either the crossover or the driver has blown or, if you're lucky there is a loose connection internally if you have only checked external connections.
Jun 01, 2013 | Mackie MR5 MR5 Reference Monitor
How do i hook up my mackie mr5 speakers to my interface? Should i plug the cables in the trs (balanced ) section at the back of the speakers
yes - trs or xlr inputs will give you the same result, as long as you use the correct cables.
Make sure the mackies are off when you plug them in or you'll get a nasty thump. Equally, make sure the volume is down on your interface initially.
Apr 30, 2011 | Mackie Mr5 Active 5" Powered Studio...
I used my monitors at high volume for approximately 1 hour and they stopped working. One monitor has no volume and the other has very low minimum volume.
You may have blown a fuse in the amplifier. Refer to Appendix A: Service Info in this guide http://www.mackie.com/products/mr5/pdf/mr5_om.pdf under No Power section, and if the fuse it not blown, try some of the solutions under No Sound. Hope this helps!
Feb 28, 2011 | Mackie Mr5 Active 5" Powered Studio...
I hooked up my Mackie MR5 Monitors to my MacBook Pro through an audio interface, I use it to record my band in the studio I use out of my basement. Except everytime I try to use the monitors they give me...
try hooking headphones to the output and see if the crackling is still there.
then, try it with the speakers, at a lower computer voume level and higher speaker volume level. perhaps the headphone output is too loud and distorting in the speaker inputs.
Nov 28, 2010 | Mackie MR5 MR5 Reference Monitor
Mackie MR5 speakers run hot even when not in use. Run very hot when using.
IF that speaker runs noticeably hotter than the other channel speaker, you need to take it to an authorized repair center. Your monitors are apparently active types, so unless you are a trained audio technician, you should refer service to the pros. Apparently, the problem is in one of the power amplifiers in the affected monitor.
Oct 06, 2010 | Mackie MR5 MR5 Reference Monitor
Tweeter is shot. Where can I buy another one.
These parts can be ovtained directly from Mackie. Please call them and have both the model number and serial number of the MR5. There are differences sometimes in the "runs" which use different actual speaker drivers. having the serial number will insure that you get the proper replacement driver.
You can locate a service center here:
http://www.mackie.com/scripts/service_centers/search.asp
Dan
Mar 14, 2010 | Mackie MR5 MR5 Reference Monitor
Replace High Frequency Transducer (Tweeter) on
You should order an exact replacement from Mackie since this is a reference monitor.
Consider putting a limiter or fuse in series to protect the speakers if this was due to overdriving it.
Sep 20, 2009 | Mackie MR5 MR5 Reference Monitor
Stand for Mackie MR5
My best advice to you is to get your stands where I get mine - on eBay. They usually have a great selection of stands, tripods (although I personally would not put my nice Mackie reference monitors on tripods - too unstable).
Also, you will most likely find them for quite a lot less on eBay.
However, I believe Musiciansfriend.com (my favorite web site) may be having a fall sale very soon, or end of summer sale, and they have been known to reduce their prices heavily on things like stands, sound reinforcement, and other accessories during a big sale.
If FixYa sold such things, I wouldn't be sending you anywhere off site, but since you cant get them through us, I am giving you my absolute number 1 and number 2 choices that should solve your problem well.
If looking on eBay, be sure to measure your monitors, or get the information from the literature that came with the monitors. It's bit easier on Musiciansfriend.com, and here is a link to the stands they havce available there:
http://www.musiciansfriend.com/navigation?q=monitor+stand
Another option is monitor wall mounts, as we have to two of four reference monitors in our home studio wall-mounted, and it's great getting them out of the way and not taking up floor space or valuable desk space.
I hope whatever decision you make will be one you are happy with.
Thank you for using FixYa.
Sep 08, 2009 | Mackie MR5 MR5 Reference Monitor
Mackie MR5 MR5 Reference Monitor Logo
365 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
 Grubhead
Grubhead
Are you a Mackie Music Expert? Answer questions, earn points and help others
