Question about Maytag Atlantis MDE6400AY Electric Dryer
Wont heat will tumble and i have checked all thermal switches all have continuty
    President:
  • 1,136 Answers
Hi, Did you check to see if there is 240V to the dryer? Check to see if the element has continuity. If you wanr, you can remove the front panel and check to see if the element is getting 240V.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 04, 2009
Not spinning
A dryer has a lot of parts to make it heat, tumble and blow air. If it quit tumbling there are many things that could be wrong. You could start with checking the thermal fuse or belt switch or door switch, from there your into timers and motors. If you have electrical experience go for it :-) unplug first ;-)
Aug 02, 2014 | Whirlpool Dryers
Maytag dryer HYG3460AWW how do I test thermal fuse onblower with 4 wires (yellow tan blue white) how do itest motor without removeing it from unit.
That thermostat your describing is the main controlling thermostat and NOT the thermal fuse however to test it the 2 with the larger wire terminals will have ZERO ohms resistiance at all times,the 2 smaller terminals will have appx.100-1000 ohms resistiance. Now then the thermal fuse will have TWO wires and mounted to the tube where the burner asm. is and it too should have ZERO ohms resistiance at all times if its good.
To test the motor the WHITE and purple wire on the motor is the run winding it will have continuty with i believe appx 10 or so ohms resistiance at all times
the start winding on the motor will also have continuty and the wires on it will be the same WHITE wire as the run winding and the orange wire
but if your dryer wont start check the thermal fuse on the burner tube first,the the door switch if thermal fuse checks to be good
GENE
Sep 04, 2011 | Maytag Dryers
Kenmore elite gas dryer won't heat.I tested thermal fuse, high limit thermostat, thermistor and gas valve. All within spec or have continuity.
Hello Chuck,
In addation to what you have checked here is a list of what else to check
Flame switch...black box on burner tube...check for continuty
Ignitor...check for 120 vac too it
Timer/control board heat relay..on models w/timer check for contunity in heat circuit on timer. ON models w/control check that heat relay on board is closing and has continuty
Motor switch..check that heat circuit is closed and has continuty when motor is running and motor switch has closed for heat circuit(the start winding switch on motor will be open when running)
WARNING..WHEN PLUGGED IN FLAME SWITCH WILL BE LIVE ALL THE TIME AND SHOCK YOU WHEN TOUCHING..BE SURE TO DISCONNECT POWER BEFORE CHECKING
Gene
Aug 09, 2011 | Kenmore Dryers
Kenmore 500 series gas dryer has no heat and no glow. Thermostat fuse has continuity. Replaced ignitor and coils. bypassed flame sensor and still have the same problem.
Having checked or replaced what you have thus far here a few things still to check
Cycling thermostat in blower housing,in addition to thermal fuse it must have continuty to be good
Timer check wiring diagram in control panel and check for continuty that are supposed to be closed when set to a normal heat cycle
Motor switch heat circuit check again with wiring diagram and see which wires on motor switch must be closed when running so dryer will heat.This a built curcuit asurring the dryer will never heat when motor is off
If your model has it check heat relay in control panel for continuty on heating circuit for relay(not the circuit that closes relay)
as far as power to the ignitor the hot side comes from timer to and through the thermal fuse and cycling t-stat, to ignitor.the neutral comes from neutral wire on cord to and through motor when motor is running and motor switch is closed
so on ignotor plug check hot wire to ground(not neutral) if has 120 vac to it timer/t. fuse/ cycling t-stat and flame switch are all good and its the motor switch is the problem.The motor switch can not replaced seperatly and must replace entire motor
Gene
No heat but tumbles. Heater coil is good. Fuse will be checked next. How do I get into the top control panel so I can check the resistors$
what you need to check is not only the heater but the 2 thormostat mounted on the housing where the heater goes BOTH should have continuty with zero ohms.The thermal fuse will cut off the motor so since it tumbles thermal fuse is good
Aug 09, 2011 | Kenmore 67841 Electric Dryer
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
Dryer heat not working not sure how to check the heat element to see if the coils are bad or just the: thermal fuse, thermostat limit switch.
to check to see if coils are bad you need to do a continuty check. Remove electrical connections on the ends of the drier element. Get your ohm meter and ohm the element. If your element is good you'll get a signal, no signal , bad element. If the element is good then the problem is more than likely the hi limit switch. Good luck on repairs
Dave
Sep 01, 2009 | Dryers
White knight 44aw not spinning and no heat
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 26, 2009 | Dryers
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Maytag Atlantis MDE6400AY Electric Dryer Logo
88 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
