Question about Kenwood DDX-6019 Car DVD Player
How do i adjust sound
Touch screen broke so i dont know how to use remote for sound only for volume
  • 3 Answers
Volume buttons are not on the touch screen, they are below it on the face of the radio and are clearly marked on the remote.
Posted on May 22, 2008
Get my dish reciever, sony home theatre, and 55in sanyo tv to work together
If your TV and sound system both have a Digital Optical Out/In you can use a TOSLink cable (an optical cable) to connect your TV directly to your sound system, and remove the connection between the DISH receiver and the sound system. As long as your sound system is on the right input, all sound accompanying the picture on screen will go to your sound system. Most TVs also have an option to turn off the internal speakers, if not just reduce your volume all the way down to avoid that weird ghost sound effect. If you use your sound system all the time for volume, you can program the sound system to your DISH remote's AUX, and even set the remote so that it only sends volume and mute commands to the sound system (that way you don't have to dance between sat, tv, and aux all day, just leave it in sat mode).
To program your remote to the sound system, follow the instructions on the sheet you got with the remote (yeah, right like anyone kept that) http://www.mydish.com/support/remotecodes you can use that link to program your remote. You can also use the learning mode if your remote has a little glossy square on the top left side and you have the original remote to the sound system. (Learning mode can be gleaned from the remote manual Remote Control Manuals)
After programming the aux device, and verifying that it changes the volume up, down, and mute, THEN:
Hold AUX until light blinks 3 times, hit pound (#), Volume Up, 0 (Zero), pound (#), SAT, then test to make sure it goes up and down.
Sep 24, 2014 | DISH Network Televison & Video
How to fix your metro PCS 4G unresponsive touch screen?
reset battery , replace the touch screen part as u broke it
Aug 17, 2014 | LG Metro Pcs Connect 4g Lte Ms840 Phone...
Dragon touch tablet manual How do I turn off the volume of the table dragon touch 10".
If you do not have "+" and "-" buttons on the side of your tablet, you can change the volume via the screen.
The link below is for HP tablets, but can be used with any Android 4.1 tablet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c03678318
On the Home screen, touch the "All Apps" icon, and then touch the "Settings" icon. In the Device section, touch "Sound".
Touch "Volumes" to select custom volumes for media playback, notifications, and alarms.
Touch and drag the circle along the slider to adjust the volume for each type of sound. Dragging the slider left decreases the volume, and dragging the slider right increases the volume.
May 17, 2014 | Computers & Internet
I have a sony bravia kdl-37v5810. sound on loud no picture buttons dont work on set or remote have to unplug to switch off.
Two pieces of information:
First thing to try is unplug the set and a box or receiver if you use them for several minutes from power, then plug things back for power and see if that helps.
Second, Sony is one of the few companies who uses the same access code to reset all their sets for the last 20 years, if it comes on and responds to the Sony original remote you can try that,
set is off, Then with the remote Display, 5, volume up, and power.
If set comes on you should be in the service menu---do not by accident touch any buttons randomly : what you want to touch is 8 (reset or write should appear on the screen in red, then hit enter and the word should change to green and the set shut off.
turn back on with remote and see what happened or not.
Dec 19, 2012 | Televison & Video
Harmony remote control - volume won't stop increasing when the button is pushed
First I would check if the remote is momentarily sending out the volume command or is it sending it out continuously. You can use this trick with any IR remote. Using a digital camera with display, point the remote at the camera and press the volume button on the remote. If the IR led is working then you should see it glow on the cameras screen. When you release the volume up button, the IR led should stop glowing. If it does not stop then you may have a sticky key or a problem with the program. If it shuts off then the Harmony is functioning ok and there is a problem with your receiver. Another way to test this is to press the volume up button and then immediately cover the remote with a blanket or take it to another room or remove the batteries. Let me know if the remote is continuously sending out the Volume command or is it momentary.
Hope this helps.
May 02, 2010 | Logitech Harmony One Advanced Universal...
Our TV has been great. Have owned it A little over 2 years. Just now the Volume line appears on the screen and the volume goes to zero without anybody touching the remote. The volume line stays on the...
Check the tv pannel manually control on the right,see if it work.Then it ur remote tries take it aparts clean it with some alchol with a Q tips there a screw under the batteries input,after that change the batteries,That one solution.The other have to take ur tv apart to change the sound board.
Sep 27, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
My lcd broke on the INSIDE on my touchscreen nikon coolpix s50
i think your touch screen is gone because it might have fallen so  it had the crack.
Jun 18, 2009 | Nikon Coolpix S50 Digital Camera
No remote any way to turn volume down with out it
YOU CAN ALWAYS ORDER ANOTHER ONE FROM WALMART.OTHER THEN THAT,I THINK IT'S PRETTY MUCH NOTHING YOU CAN DO..
Jun 06, 2009 | Car Audio & Video
No sound when on internet radio, playtime is running, volume is not muted, internet ok
It was solved by turning the receiver off with the power button (not stand-by). After turning on the netradio did have its sound back. Apparantly it must be running some sort of Windows os.
May 16, 2009 | Denon AVR 3808Ci Receiver
Samsung remote volume control returns to max sound on its own
dear, you have to check your +button whether it is holp the egde of your remote, open your remote and clean, and also check a button on tv for +volume button. there is a pulse condition sensed by the volume control stage. if you can manage do it, or take it to a technician.
Feb 26, 2009 | Samsung Remote Control
Kenwood DDX-6019 Car DVD Player Logo
65 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
