Question about Intel D850MV Motherboard
Black screen even the power is ok!!
I tried to power on my PC but it is doesn't show anything on the desktop, it is only a black screen.
I tried to use the working memory RAM and it is still not showing anything even the BIOS setting.
Please if you can help to solve this problem....
If its working perfectly before. You might have a defective board issue
Posted on Jun 18, 2009
    President:
  • 2,351 Answers
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; http://www.intel.com/support/motherboards/desktop/sb/cs-009010.htm This next link shows a compatible AGP video card that will replace your old card; http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4116644&csid=ITD&body=MAIN#detailspecs Thanks for using fixya
Posted on Jun 04, 2009
My hp laptop TPN-C126 has power but its screen was totally blackout
that TPN-c126 is not the model number
In fact its the EPA/EU, power (sleep )and energystar
regulations RMN:TPN-C126 (the R means gov. regs)
proof here:
http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/europe_erplot3_notebo_201542919128520.pdf
if you look again at the back of pc. base.
on the right side of where you where looking
is a SERIAL.(I dont want that)
then below that, is model
"HP 255 - G5" (or very close)
when posting use real names and models
as seen here
http://partsurfer.hp.com/search.aspx
click Hierarchy
then notebooks
then hp notebook PCs
behold. photo below.
one is yours, matching words on bottom of your PC.
LT black screens
http://pcdied.com/black-screen.html#Laptop
below is your pc if you knew its real name.15cdf60c-9764-4e4a-a480-66af380fe0ab.jpg255-g5-hmzm4reoidw0tx1unypabkrd-3-2.jpg
Jul 21, 2017 | HP Computers & Internet
Graphics drivers windows 7
Right click on the desktop and a pop up menu will appear. Three items off the bottom select 'Screen Resolution' and click it. A new window will appear, in the centre are 4 options, choose the drop down menu (small black triangle) against Resolution. It will most likely be showing 640x480 in the window. Click the drop down menu and select your required resolution, the best one for your video card will have (recommended) against it. Click OK and wait for your screen to refresh. You should see a confirmation message asking to OK the change. If you do not see that DO NOT TOUCH any keys or buttons for a minute or so. If the screen went black and stayed that way you have chosen the wrong one. By leaving the keys alone for a minute, the display will automatically revert to the last setting thereby giving you the option to try a different setting. If you touch anything whilst the screen is black you may not see anything again, be warned!
Dec 21, 2013 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have a Toshiba Satellite L505D-S5963 laptop computer. I cannot get my desktop to come up. The screen is black. How can I solve this problem.
hmm ok try this
restart computer with F8 pressed down and see if it goes to SAFE mode
if it does report back
May 24, 2012 | Computers & Internet
I have Hp 6730s, when I push start button it doesnt show anything just a black screen, The ON lights work and also the fan. I tried firstly to connect it with a vga screen and it doesn't show anything...
forgive but i do not believe its a screen problem if it was when you connected it to the vgha it will have shown your display. you may have a VGA problem you might have to consider refering to a technician to have it fixed for you
Aug 10, 2011 | Computers & Internet
Screen is black
Try connecting it to a external monitor and see if it comes on. If now then most likely due to a faulty GPU. Check out www.bootmylaptop.com for a DIY repair guide.
May 21, 2010 | Compaq Presario Notebook
Vista Black Screen after Startup.
Try booting into SAFE MODE, usually by pressing F5 or F8 just after turning the power on. This should give you a display. Once you can see your desktop right chick on a blank area of the desktop, select PERSONALISE, then DISPLAY SETTINGS to reduce the screen resolution. Then reboot and try again in NORMAL Startup
Jul 27, 2009 | Microsoft Windows Vista Home Premium for...
The screen is too dark to read anything though the power comes on. i tried to increase the brightness but did not work NEED HELP!!!
Sounds like your backlight or inverter is on its way out. You can pick one up on ebay.  Google how to check backlight/inverter issues with your model.
May 02, 2009 | Computers & Internet
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Mar 11, 2009 | Dell Computers & Internet
Intel D850MV Motherboard Logo
160 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
