Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
My hppavilion f1503 flat panel lcd monitor screen stay blank
When i plug in the dell desk top pc it just stay blank but the light on the power light is on . i try to turn the power light on and off but the sceen still stay blank/black.i plug my pc on my other flat screen monitor and my computer works fine with that. please help. Is the bulb bad thats what my friends who gave it to me were guessing? Do i need a driver disk to recognize the monitor? Is this monitor plug and play?
    Scholar:
  • 47 Answers
The monitor should be plug and play, and you've already figured out that it's not your computer by plugging into a working monitor.
This is most likely the power inverter board in the monitor - this is common in many monitors. If the power light is blinking on-and-off, or just staying on with no image, that's the problem. There is a slight chance that it could be the light itself, but inverters fail more commonly.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Posted on Jun 06, 2009
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Screen goes black after booting up
amprich63, You should try to evaluate the state of the "switch-mode-power-supply" in the F1503 unit. Reconnect it to a FULLY booted KNOWN GOOD PC that is currently displaying the WIN-desktop screen! Then and only then push the "ON" button for the F1503. Did you see the desktop window?? if only for 1 second? What did you see next? Did you see a BLACK and BLANK screen? or Maybe just a BLACK screen? Do another post to this and tell me EXACTLY what you see or don't see when you shine a bright torch 2-3cm from lcd panel!!! I think you may have a BACKLIGHTING or POWER SUPPLY problem. I'm12fixlouie on fixya. if this was of some help rate this on fixya
Nov 02, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
MY HP 1502 MONITOR STAYS BLANK BUT POWER LIGHT FLASHES
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old your monitor is, and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Jun 06, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Dell Blinking Power Light
Hi There,
I have worked on several of the Dell 17" and that is almost always the Capacitor problem.
The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
If you can get inside the frame of the monitor, and disassemble, you can find the caps by seeing a bulge on top, or even a rusty looking material on the top. Be VERY careful around the high voltage section if you do go inside.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 04, 2009 | Dell E153FPf 15" TFT LCD Flat Panel...
LCD Monitor Blank/Non-Responsive - Dell E173FPC
Next thing I would check is the VGA cable between PC and monitor.
Make sure is in at both ends and if possible try another one.
Do the Dell Menus come up with no VGA cable plugged in? Is the light amber? Flashing or static?
Mar 18, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
My E172fp has a blank screen...when i unplug and plug it back in,the "dell dimension" or whatever that logo is comes on for a second, then the screen goes blank and stays that way.another monitor works...
i have the same issue before with my DELL 2001FP, I replace the 3 capacitor on the board that look like defective because the top is look like swolen, it should be flat. I replace it with the same value and now the it works better.
i hope this might help .
Feb 25, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
HP Monitor comes on with bright white screen since changing PC
Try using a different wall outlet to plug in your monitor. Believe it or not this actually may help.
What ever breakers you are talking about to get the monitor going doesn't really have anything to do with the drivers. Monitors are "plug and play" meaning the drivers are installed for you when you plug it in. It"s possible you don't have the connections on securely or maybe one of the pins are bent. Does it say "restore active desktop" anywhere on your screen?
Also possible the power supply isn't strong enough for your lcd.
Dec 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Sep 16, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
