Question about Hotpoint First Edition FEW12 Front Load Washer
Shakes violently Ever since having the machine 2 years ago it moves around violently when spinning. I've tried keeping it level, so that isn't the problem, I'm now moving it into the kitchen between units and need to stop the vibrations.
  • 1 more comment
  • Lochore Oct 24, 2007
    This problem has been from new, so is it the bearings?
  • lisa2008 Jan 05, 2008
    ive just brought a new hotpoint machine my partner connected it i dont know if he's done it wrong as when i put it on to wash it moved out from under the unit and half way across the kitchen floor. I have to hold it every time it spins. Surely a brand new machine shouldnt be doing this?! Any ideas?
  • LizHaynes May 09, 2008
    I have the very same problem with my unit and we have tried leveling it out, what else could it be?
  • 24 Answers
The bearings of you machine are damaged or bad..You have to get em' replace..until then lowering the water pressure will solve this problem to some extent..
Posted on Oct 24, 2007
  • Devi Priya Priya
    Devi Priya Priya Oct 24, 2007
    Oh!Then try this...A new washer usually shakes or vibrates when it isn't sitting firmly and
    level on the floor or because it has an out-of-balance wash load. First
    eliminate the possibility of the latter--adjust the load if it has
    scrunched up on one side of the tub. Then check the machine for solid,
    level support. To work properly, the floor must be flat, level, and
    strong enough to support the heavy, water-filled washer without
    deflecting under the load.
    1) Unplug the washer.
    2)there may be some thing under the tub obstructing the spinning check for this
    3)Look under the front of the washer and make sure all feet are resting firmly on the floor.
    Make sure the front legs have locking nuts to keep them tight and the
    legs have rubber caps. If they don't pick up these parts and install
    5) Make the front feet as short as possible by screwing
    them up into the machine. Place a level on top of the washing machine
    and adjust the front feet slightly to level the washer, but do not
    fully extend them. Keep them as short as possible.
    6) If
    necessary, tilt the washing machine forward. This will let the back
    feet self adjust (most recent models do this automatically). Recheck
    with the level and adjust the front feet again.
    7) Plug in the machine and run it empty through the spin cycle to see if it still vibrates.
    8)Also make sure has the transit brackets been removed, these are bolts that secure the
    drum while its being moved, failing that this could be a call out under
    guarantee, the bolts and location of where they are etc are in the
    instruction leaflet
Remove the top of washer by removing covers on top side edges and unscrew torx screws. then slide back lid to remove. then check the concrete block is insitu, and there is hydrlic shocks one on each side of macne make sure thes are conected etc.
Posted on Dec 15, 2007
Hotpoint wt741 shakes violently
Washers utilize spring loaded legs for self-balancing or threaded screw in feet that uses a manual locking nut.
If unit is level and sitting solid on the floor,you may have a stabilizer issue or a weak wooden floor.
Nov 26, 2017 | Washing Machines
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
May 14, 2010 | Washing Machines
Maytag lat6914aae top load washer shakes violently in spin cycle
A washer can have self leveling legs at the back. If they are rusty or clogged and not free to move, they will not self level and the machine will rock when working. Check the leveling apparatus, it's a bunch of metal pieces going across the lower back of the machine. Spray them with a lubricant and move them to make sure they are free.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Shook Violently first time on spin cycle
Make sure the washer is leveled properly and all four feet are resting on the floor. If it is level, try running one cysle without any clothes in it to see it is spins without that violent shaking.. you may have also had an out of balance load.. Hope that helps!
Aug 13, 2008 | Samsung WF337AA Front Load Washer
Shakes Violently
run it with the top access panel open and watch,
while you are there try out the suspension ,
you do it like an old car push it down , push to sides etc .
it should resist and return well. no bounce. tight.
May 15, 2008 | GE WBVH6240F Front Load Washer
Washing machine shaking on spin cycle
what is the brand of the washer along with the model nunber
Apr 12, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Hotpoint First Edition FEW12 Front Load Washer Logo
118 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
