Question about Canon imageRUNNER 5000 Copier
Connecting pre-networked ir5000s to imagepass L1
I am trying to connect a IR5000s to an imagePASS L1 and the imagepass will not recognize the copier.  In the instructions I am told I need a mn-cont version of at least 50.04 and I have version 20.01.  Our local service tech tried to update the version without success.  I was told I needed a complete print controller upgrade to accept newer programming.  Is this neccessary?  What would need to be done?  Thanks!!!
  • Canon Expert
  • 287 Answers
Hello copierhelp. I could have sworn I responded to your request before but "fixya's" records don't seem to reflect that. So here we go. Your controller should be able to have its firmware (ver 20.01 changed to 50.04) updated as opposed to replacing the controller. This does however require a tech that is recognized by Canon as being trained,certified and currently working for a certified service dealership. If that is so then the tech will have access to the unique tool required to upgrade your firmware. And the tech will have access to the web site that has the library of firmware available for your machine, which the "ServiceSupportTool" will use to complete the upgrade. Additionally, the tech will have to go into service mode on the copier and change the settings which tell the copier that it no longer in charge of its network interface and the L1 is in control. This answer may cause more questions and angst than you wanted, and I am sorry for that, but I truly hope to help you out. let me know if I was any help and if you need anything. good luck.
Posted on Jan 06, 2008
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
How to print to Canon ImagePASS-M2 (connected to iR105) from Windows computer
If you connected it directly to a Windows computer, then, on that computer, "share" that printer, so that any computer that can connect to that computer can also access that printer.
You probably need to download software from Canon's web-site and install it on each computer that wants to print to that printer/copier.
Apr 29, 2014 | Canon Office Equipment & Supplies
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
Oct 29, 2009 | Canon imageRUNNER C3200 Copier
Printing speed slow
Try to run a clear server on your imagepass. (unless that is what you meant by clearing RAM)
You also may wish to restart the M3.
If you have a support contract, ask your dealer to upgrade or reinstall your fiery system software.
Mar 27, 2009 | Canon imageRUNNER 105 Copier
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Installation of printer fiery
Depending on the model of the imagePass controller attached to your 5000(L-1?), the drivers can be found here:
http://www.usa.canon.com/html/download/imagepass.html
Nov 01, 2008 | Canon imageRUNNER 5000 Copier
The Cannon Imagepass L1 cannot connect to Imagerunner
set service mode->copier->option->int-face->img-cont = 1
Jul 25, 2008 | Canon imageRUNNER 5000 Copier
Scan to e-mail using Canon ir5000
cant be done with the ir5000s, only the ir5000i. The 5000s only does whats called "pull scanning", where you put the document on the copier and then go to your computer and use an application to "pull" the scan from the copier to your desktop. You can then attach the image to an email and send it that way.
Jul 18, 2008 | Canon imageRUNNER 5000 Copier
E602 0001 for canon ir5000s
THIS IS TOO EASY ...
HARDDISK IS FULL.YOU MUST TRY TO CHANGE HARDDISK OR RE FLASH PROGRAM BY SST V3.5
Aug 26, 2007 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
228 people viewed this question
old marine
old marine
