Question about HP Compaq Presario F750US
Synaptics touchpad not working properly
My synaptics pointing devise freezes and then moves randomly across the screen without me touching it (moving rapidly in the up and down direction). I've updated the driver, rebooted, adjusted the settings, nothing works. This random movement usually continues until I hibernate my laptop. After a few minutes, it starts again. I am able to use a wireless mouse but I sometimes have to turn off the touchpad.
  • nlgant Jun 04, 2009
    Still having trouble. When the pointer is moving by itself, it will stop when I touch the touchscreen but I can only move the pointer up and down. When I take my finger off the touchpad, it moves again all by itself. Any other ideas?
  • 453 Answers
Hmm give this method a try. Turn off computer remove AC power adapter. Remove the battery and press the power button for 30 seconds continuously. This removes the static from the system. This process is called as Power drain. This works in most of the cases. Good Luck !!!
Posted on Jun 04, 2009
  • p_nivas
    p_nivas Feb 21, 2014
    Great. This simple solution worked for my Inspiron N5040 latop. Thanks.
Dell Vostro 1510 (Win 7) - Can't enable/disable the Touchpad
There is an option to disable the internal touchpad when you connect and external mouse. Please check the screenshot attached.
May 06, 2017 | Dell Vostro 1510 Laptop
I have a Sony Vaio and though the touch pad allows the cursor to move around the page it does not allow me to click on anything. I have a Logitech mouse that I use but that is because the touch pad is not...
You may need to enable the buttons for Sony Vaio Synaptics TouchPad as follows...
1. At the bottom left of the screen on the Taskbar, left-click on start.
2. On the pop-up window, left-click on Control Panel.
3. In the Control Panel window, left-click on Sony Notebook Setup
4. On the Sony Notebook Setup pop-up, left-click on the Device tab.
5. Left-click on Pointing Devices to high-light it, then left-click the Settings button.
6. On the Mouse Properties pop-up window, left-click on the Device Settings tab.
7. On the Devices listing for Synaptics TouchPad, left-click the Settings button.
8. On the pop-up window Properties for Synaptics TouchPad on PS/2 port....
9. Left-click on Buttons item to bring up a Buttons frame with an Enable buttons check box.
10. If the check box is not checked, left-click on it to enable the buttons for the TouchPad.
11. Left-click Apply button or OK button to enable TouchPad buttons and exit the pop-up window.
Feb 01, 2011 | Sony Computers & Internet
The touch pad its not working properly on my hp pavilion dv7
my buddy brought his to me last week with this problem he could move the curser but had to hit the button to left click when he tap on the pad it did nothing you may have changed the configuration in Synaptics Touchpad you may have diabled certain settings in it i usuallu has a icon to the bottom right near clock it should be a red symbol it might say Synaptics pointing device when you but cursor over it
Sep 02, 2010 | HP Pavilion dv7-1240us Notebook
I have a Dell laptop computer with Windows Vista Basic. The mouse on the screen has become very sensitive and sometimes it clicks on an item when it scrolls across the screen. How can I make it less...
  1. Right-click on the desktop and select Personalize > Mouse Pointers . The Mouse Properties settings window will open.
  2. Alternately, click Start and type Mouse in the Search field, and select Mouse when it becomes available in the program list. The Mouse Properties settings window will open.
  3. Select the Device Settings tab. Select the Synaptics TouchPad device and click Settings . In the Properties for Synaptics TouchPad window, expand the Sensitivity topic.
  4. Select the PalmCheck option to adjust the sensitivity of the touchpad to avoid erratic cursor movement caused by accidental touching of the pad during normal typing.
  5. Select the Touch Sensitivity option to adjust how much finger pressure is required to move the mouse on the screen and how responsive the touchpad is to taps.
Jul 12, 2010 | Dell Vostro 1000 Notebook
I don't know how to use the scroll areas to the Right and Bottom of the Touchpad on my Dell XPS M1730
There is a software that comes preloaded with dell called Synaptics Pointing Software .See to that it is installed.From the software enable the required scrolling mode.by moving your finger up and down slightly pressed along the right most areas of the touch pad allows vertical scrolling while moving the finger horizontally at the bottom side of the touch pad allows horizontal scrolling.Also see to that the synaptics software is enabled at startup
Sep 29, 2009 | Dell XPS M1730 Notebook
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
Synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
Touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Mar 14, 2009 | HP Pavilion dv4000 Notebook
Synaptic Touch Pad randomly moves pointer on screen
try going to synaptics website and updating the driver for this device, I had the same problem, after I updated it was fine
Mar 12, 2009 | Computers & Internet
My laptop pad is very senative how do i ajust this?
there doesnt seem to be a setting in the synaptics touchpad menu for this so you will have to reset the touch pad, go to my computer>properties>hardware tab>device manager and go down list to mice and other pointing devices. Click on it and you should see synaptics touchpad, right click,and select uninstal. Restart laptop and the driver will re install synaptics driver and set it back to default.
Apr 08, 2007 | Acer Aspire 3002LCi Notebook
HP Compaq Presario F750US Logo
571 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
