Question about Home
Have a 1991 Jacuzzi 2 HP 220/110 pump. need wiring help
Took the little plate off the motor. how do I know if it is wired for 110 or 220? the power cord it attached. just bought it off eBay. runs fine, super quite, then a click is heard in the capacitor box on top of motor, motor quits, then restarts in about 5 minutes. am running a 120v line. any help?
  • 323 Answers
If you are running a 120 volt line then there is no way it could run 240. Did you wire it yourself? A 240 would have a hook up in the box for a red hot wire, a black hot wire, a white neutral, and a green or copper ground wire.
A 120 would have a white neutral , a black hot, and a green or copper ground wire. It wired correctly, you may need to replace the capacitor. But be certain you have cut the power to the circuit off at the panel.
Posted on Jun 04, 2009
Wiring of the 2-5-10-15 timer to a jucuzee bath tub it has three wires black blue green. Thanks. Terry.
First thing to consider is size of Load.
Leviton countdown-timer Load rating is 1800 Watt, 120Volt.
Look inside Jacuzzi at rating plate on motor.
Rating plate on motor should give Volts, Watts and Amps.
Formula Volts x Amps = Watts.
Sometimes motor shows VA which is Watts
Is Jacuzzi on 240Volt breaker or 120V breaker?
Leviton countdown timer is not for 240V load.
A) If 120Volt electric Load checks out, here's how to wire timer if 1 cable enter box.
Timer-black-wire connects to jacuzzi-black
Timer-white-wire connects to ground.
Timer-green connects to ground.
Timer-red connects to jacuzzi-blue.
B) Here's how to wire timer if 2 cables enter box.
120Volt cable coming from breaker box has black, white and bare copper wire.
Timer-black-wire connects to black-wire-from-breaker
Timer-white-wire connects to white-wire-from-breaker-box.
Timer-green and jacuzzi-ground connect to ground
Timer-red-wire connects to jacuzzi-black-wire.
Jacuzzi-blue-wire connects to white.
I am puzzled why this wire is blue if circuit is 120Volt.
Nov 26, 2010 | Leviton Timer Switch 2-5-10-15 Minutes, 4...
Inead a new timer for a jacuzzi
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First thing:
Determine Hp (horsepower), wattage and volts. There is a label that shows these values
1) Indoor Jacuzzi pumps are usually 115Volt and 1 Hp to 1.5 Hp. 1 Hp or horsepower is 746 Watt, 1.5 Hp is 1119 Watts
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Which timer? If wiring is already connected to a switch, ordinary in-wall 15Amp timer can handle up to 1400 Watts.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 2) Outdoor Jacuzzi or Hot Tub pumps can be 115Volt or 240Volt and up to 5 Hp. 5 Hp is 3730 Watts
Which timer?: Wide variety of Pool and spa controls at Aplus
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.aplussupply.com/intermatic/timerpool.htm
If you need more help, re-post electrical details about your jacuzzi and exactly what you want timer to do.
Sep 19, 2010 | Jacuzzi Hardware & Accessories
Pump cutting in and out, seems to downshift up and down with powe
You will need to check the power gettin to the motor. Sounds like one leg of the power is down and only 110v are getting to the motor. Remove the wires from the motor and check each leg against ground. Hope this helps and good luck.
Apr 09, 2010 | Jacuzzi Impeller, L - 3/4 H.P
Pool pump
check to be sure that the motor wireing is the same as the wireing going to it 115or230 most motors can be converted look on motor for wire diagram.
Jul 04, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I have a jacuzzi 1/2 hp submersible well pump. Does this need any regular maintainance to keep it happy.
No preventative maintenance is necessary. However, a happy pump always has water above it and should not pump sand. If the water level in the well is below the pump/motor they will overheat. If this is a problem your local pump company can install a module to protect your pump from this type of event.
Please rate this answer.
Jul 03, 2009 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Jun 01, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Apr 11, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Do Magnum Force Pumps have a reset switch ?
No jacuzzi magnums do not have a reset button. First make sure breaker to pool is off, then remove rear motor cover, and take a look. Popping noise sounds like an arked wire. Could be a bad terminal or just aloose power wire. JACUZZI PUMPS ARE GOOD QUALITY, AND USSUALLY RUN FOR MANY YEARS. Pump can be removed for repaair, or motor replacemant by a qualified, and republe pool shop, for rebuilding Ussually rebuilding is about half the cost of new. Kirk
Feb 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Need to know what you call the plastic bulb side of pressure tank
this is a water systems pump. Made now by Franklin Pump Systems in Ohio.
Dec 31, 2008 | Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire...
Home Logo
198 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
