Question about E-Machines eMachines Desktop PC
Emachine will not power up
Green light on motherboard is on, but nothing else model t2862
    Problem Solver:
  • 8 Answers
By nothing else, from a technical standpoint this would mean literally nothing, the CPU fan, power supply fan, aux fan, disk drive not spinning up, etc. My experience with EMachines is their motherboards aint the best, have been known to take out hard drives and other peripherals to the mother board. If you are technically inclined the first thing to do is to bare out the system, Power Supply attached to the Mother Board w/ Cpu Monitor and Keyboard no Hard Drive and no Non esential boards installed, very carefully remove the memory and start it up all should be fine except it should give you a long beep from the PC Speaker indicating the Mother Board is aware there is no memory installed if it will not do this most basic of tests this is not good. If it does give you a health beep continue to install one item at a time, first the memory, the display should, if working, tell you there is a boot failure, of course, the hard drive is not connected, do so and keep on testing. Without knowing what type of mother board you have, most likely an AT with integrated peripherials the process to determine exactly what the problem is would take hands on trouble shooting. If you dont get the beep indicating the mother board cant determine if memory is installed and truley nothing else is on it is more likely the mother board. There are several good ones online that will fit your case if you want to go this route. Or is it time to upgrade ?
Posted on Jun 04, 2009
I have emachine t seris t2862 desktop and I donnot know how to connect power swich in mother board please help me
On the motherboard there will be a small set of connectors marked FPANEL, next to each of these will be a set of letters (usually PW, RES, HDD, MSG) and an earth pin, From the power switch you will see a two wire set normally black and white ending in a connector, this connects to the PW pins on the FPANEL
Jan 06, 2011 | E-Machines eMachines Refurbished EMA...
Emachine T2958, tested power supply (good). Green
Is your PC making any beep sounds, anything at all on monitor? if nothing try removing cpu then re-install cpu?
Feb 09, 2010 | E-Machines (T2958) PC Desktop
I am looking for the specs for a motherboard for a t2862 emachine, more specific for the connection from the mother board to the on/off switch
This is a link to an UN-Official eMachine website: http://www.e4allupgraders.info/ . I found your motherboard but NO info on the jumpers. It is an Intel motherboard but they're website has no info either. So, on the right side of the eMachine page there is a eHelp Forum. They should be able to get the right pins for your power switch.
Oct 25, 2009 | Computers & Internet
T2862 wont work -no power goes to it.
emachine?
is it new?
if its not, then check the power supply, there should be a green light on the back of the unit. if this is yellow or not lit at all then the problem is your PSU
crack the case and make sure the PSU cables are connected properly
also while your in there check for swollen capacitors or dust
Sep 04, 2009 | E-Machines eMachines Desktop PC
Can not find heat sink switches on motherboard emachine t2862
Heat sink switches? I have to assume that you're talking about a dead mother board but the fans and the LED on the mother board are OK? This is a classic eMachines problem. Their power supplies glitch and take out the mother board sometimes the power supply goes bad too.
Mar 24, 2009 | E-Machines eMachines Desktop PC
Emachine T2862
have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Feb 01, 2009 | E-Machines eMachines Desktop PC
Emachine T2862
It sounds like the motherboard is toast
Didn't find anything on EBay for a motheboard
You can get a replacement Dell wo/monitor for $299 +Tax/shipping
http://www.dell.com/content/products/category.aspx/desktops?c=us&cs=19&l=en&s=dhs
Jul 10, 2008 | E-Machines eMachines Refurbished EMA...
E machine no power
Make sure the RAM is seated, the CPU, any video card and the Power supply is properly connected.
If you power it on, still get no POST (beep at startup from the PC speakers) its time to replace the motherboard.
Feb 01, 2008 | E-Machines eMachines Desktop PC
Intel emachine t3828
Geeze, after working on hardware for 27 years i love the short circut dummie. Anyway yes, it's the motherboard / yes the green light will still come on on that model and quite a few other models. Dont worry about repairing / i.e. removing components on the motherboard, it's a fruitless endevor but a great way to waste time. A motherboard for that model will cost about 100-150 bucks / easy replacement. It's actually rare for both the power supply and mother board to go out on a tower/mini tower type system. Older laptops had that type of prob. Those emachines were **** for the mostet part. On the other hand Gateway has really gone up in quality and i have been quite impressed with them in the last few years...
Jan 14, 2008 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
EMACHINE t2882
Are the pins from the switch to the motherboard connected properly?
Could be a faulty switch on you case. T
ry shorting out the two power on pins (on motherboard) with a screw driver but be carefull not to touch anything else with it!! :)
hope this helps?
Jan 06, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
369 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
