Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Maytag DWU9200BAB jetclean dishwasher with broken door springs. found a small piece of white plastic after hearing a loud bang. How can I get to the springs to replace them? I believe the plastic is from the sping linkage.
4 Suggested Answers
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
abhishek33
  • 1239 Answers
SOURCE: MAYTAG JETCLEAN QUIET PACK
hi Replacing the Door Gasket
If water leaks through the dishwasher door, the gasket is probably faulty. Open the door and examine the gasket. It should be soft and resilient. If it's worn, cracked, or hard, it should be replaced.
Once the gasket is in place, check it for fit against the door frame. It should fit tightly with no cracks or bulges between the gasket and the frame. If necessary, tighten or loosen the retaining screws, or refit the gasket in the clips or the door channel. Then run the machine through a washing sequence and check for leaks.
If you spot a leak, and the gasket seems to be properly in place, try adjusting the door latch. The trick is to position the gasket against the frame of the door without flattening the gasket or squeezing it too flat when the door is latched properly. Adjust the latch or the gasket until it fits snugly against the door frame.
Posted on Oct 10, 2008
Kenmore washer loud bang in spin
Great!! Thanks for the followup -- I mean really, thanks!!
May 02, 2009 | Washing Machines
Broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Dec 14, 2008 | Dishwashers
Oct 10, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Dec 20, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
133 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
