GBC Eagle 35 Laminator heats up, won't turn
Laminator has no running time on it, it is in brand new condition (out of the box)
Laminator heats up fine but rollers will not turn.
I have pressed in all the "safety" switches I can find but still no movement when I press the run button. Any ideas??
  • Anonymous Feb 24, 2009
    Same here, Have you tried changing the fuses?
If you cannot get this fixed....i will buy it for spare parts.....408-802-3843
regards Cliff
Posted on Mar 15, 2010
  • 135 Answers
I have seen issues with the safety switches on the clear front cover (both sides) not getting pressed even though cover is shut, also there are switches under the feed table so it has to be set correctly (pins) let me know if this helps
Posted on Aug 05, 2009
Someone jammed our GBC Ultima 65 laminator and now it won’t turn on. I tried to toggle the circuit switch but it won’t move! What next?
The motor may have overheated and gone into thermal shutdown as a result. Probably either a protective device or the entire motor will have to be replaced.
Dec 08, 2017 | Gbc Office Equipment & Supplies
Why is my GBC Ultima laminator beeping?
It will beep when you turn it on to acknowledge power. It will also beep when it reaches ready condition. Your laminator has safety switches for the lower feed tray and upper heat shield. Any time the upper shield is lifted the power is shut off. When you lower it down the power is turned back on, causing a beep. The same is true for the lower feed table. When it is removed and then re installed the machine beeps. These are safety features so that the laminator doesn't turn on when you are reloading it or unjamming it. Check that the safety switches are fully engaged if you get unnecessary beeping.
Oct 25, 2016 | Gbc Office Equipment & Supplies
My GBC ultima 65 laminator is making loud noises. How do i fix this?
You probably have 1 or more heat roller bearings seizing up. This is a common problem. There are 2 on the left and 2 on the right. I would recommend changing both of the bearings on the side that is noisy. They can eventually stop turning and then your laminator will probably stop also.
Aug 10, 2015 | Gbc Office Equipment & Supplies
Why won't someone answer the ??s about the GBC Pinnacle 27 power light in the back works, but no power
Each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime......
Westco Laminating Service 405-324-6092
Aug 09, 2014 | Gbc 1701720: Pinnacle 27 EZload Laminator
Laminator won't heat up
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
Jan 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
My gbc creative laminator won't heat up
We have an Ulitma 65 and it won't heat up...Any suggestions on how to fix this? We are at a school and no $ to replace the whole unit. Thanks in advance.
Mar 29, 2013 | Office Equipment & Supplies
The heat button won't turn on
either the top or lower heater shoe TCO is blown out. take the right side cover off, trace the wires back to the heat shoe and check for continuity, (unplug machine first) find out which TCO is blown order another one, replace it and your off to the races. I've fixed many of them.
Mar 11, 2013 | Gbc 1701720: Pinnacle 27 EZload Laminator
GBC Pinnacle 27 won't come on
each heat shoe has a small thermal fuse, if either fuse is blown, the laminator keypanel will not operate. 99% fix everytime, just follow the wires from each heat shoe (right side of laminator) cover off. Ohm each set of wires and look for an open circuit. replace fuse (TCO) and it will work everytime.
Feb 20, 2013 | Gbc ® Pinnacle 27 Two-Heat Roll Laminator,...
My laminator won't stop heating
so what model are you having troubles with
Aug 30, 2012 | Gbc HeatSeal H425 Laminator
1,299 people viewed this question
k24674
jasbo
jasbo
