Question about kawasaki Full Suspension Mountain Bike Men
I have a 1991 kawasaki voyager with a L.I.D. problem.
I installed a new L.I.D. headlight on my 1991 voyager and I have a problem I hope that someone can help me with. When I start the motorcycle the headlight comes on but when the light is switched to high beam it works, but when the light is switched to low beam it stays on high beam and the only way to get it back to low beam is to turn the ignition off. Any help with this problem would be appreciated.
    President:
  • 2,559 Answers
The head light relay is sticking closed,You will need to replace it.
Posted on Jun 03, 2009
1991 Kawasaki ZZR 250 headlights not working
Hi, Anonymous if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chafed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/low beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.zxforums.com/forums/zx-7r-forum/106457-no-headlights-high-low-everything-else-works-searched.html
Headlights Stopped Working KawiForums Kawasaki Motorcycle Forums
Kawasaki ZZ R250 Service Manual Page 2
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 17, 2014 | 1991 kawasaki ZZR 250
1991 Kawasaki VN 1500 Vulcan Classic headlight does not work
Hi, Cwwood74 if your headlight is not working, intermittent, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/45504-headlight-problem-vulcan-1500-a.html
Headlight not working help please
http://serwer.robert.webd.pl:30/manual/Kawasaki_VN_1500_87'-99_Service_Manual_ENG.pdf
http://mybikemanuals.com/kawasaki
Aug 08, 2010 | kawasaki VN 1500 Vulcan Classic...
Can we install quad headlight in plymouth 1999 grand voyager. I want to replace my yellowish headlight (non quad)
Whiloe I am uncertain about the quad headlight for this van, they do though have kits for repairing the lens of the stock headlights. These kits include several sheets of a fine sand paper and a polymer that is applied to bring back apperance. I have used these kits several times with excellent results. It will cost you less than $20.00
I hope this may have assited,
Tom
Apr 07, 2010 | 1999 Plymouth Grand Voyager
Headlight replacement on a 1991 pontiac grand am
Sealed Beam Type
  1. Disconnect the negative battery cable.
  2. Unfasten the headlight bezel attaching screws, then remove the bezel.
Remove the headlight bezel
To avoid turning the vertical or horizontal aiming screws, refer to the illustration before removing the headlight retainer.
  1. Unfasten the headlight retainer attaching screws, then remove the retainer.
Remove the headlight trim screws then...
... pull the trim off while holding the bulb
4. Pull the headlight out, then carefully detach the electrical connector.
Pull the bulb out far enough to disconnect the wiring
To install:
  1. Attach the electrical connector to the new headlamp.
  2. Place the headlamp into the socket.
  3. Install the retainer, then tighten the attaching screws.
  4. Connect the negative battery cable, then turn the headlight switch on, to be sure the headlights are operating.
  5. Install the headlight bezel and secure using the attaching screws.
Jan 18, 2010 | 1991 Pontiac Grand Am
Describe your 1991 Oldsmobile Calais .When I turn the car off with the headlights on the car keeps running. When I turn the headlights off the motor turns off. ALso the tail lights and instrument lights...
It's not the ignition switch. Someone has been playing with the wiring. What was done to your car? Did someone wire up something to work that didn't or did someone install something that had to be wired like a stereo? Somewhere the parking light circuit has been wired to the ignition 1 circuit.
Sep 03, 2009 | 1991 Oldsmobile Cutlass Calais
Headlight does not work on my 1991 kawasaki vulcan 750
check the head switch tht could be the culprit!
Apr 18, 2009 | 1995 kawasaki VN 750 Vulcan
Need service manuals for Kawasaki voyager zg1200 b4
I found this on ebay motors it had 11 days owner has 4 copies. hope this helps.
http://www.ebaymotors.com
type in below:
NW KAWASAKI VOYAGER SERVICE REPAIR MANUAL ZG 1200 86-03
p.s. Seller:s.gif s.gifchaplinkawasaki
Feb 06, 2009 | 1992 kawasaki Zephyr 1100
Need a (free) wiring diagram for headlight on 91 Kawasaki Voyager
try this site http://www.manualz.info/
they have mauals online for a lot of bikes.
hope this helps
Jan 02, 2009 | 2001 kawasaki ZRX 1200 S
kawasaki Full Suspension Mountain Bike Men Logo
144 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
