Question about Polaroid FLM-3734B 37 in. LCD HDTV
High pitch tone from tv
37" poloroid flat screen has a high pitchsound it semsto get lower the longer it is on, but seems to have gotten worse any clues
    Genius:
  • 1,139 Answers
Hello, This is either a problem with the ballast or the switching transformer in your set. These two components often have this problem. The ballast supplies the energy needed to fire the backlight used to light the LCD screen, and the switching Power Supply Transformer helps with the conversion of AC to DC and DC to pulsating DC and then to DC again. These components are under constant stress, and they tend to cause this problem. In addition the circuitry attached might be causing the electrical stress and should be looked at also. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
I have a magnavox 37mf331d/37 that has developed a high pitched whine.the longer the tv is on the louder the whine.the tv is 5-6 yrs old
It's likely a capacitor associated with the power supply having gone bad.
It's obviously beyond your expertise to repair it yourself.
Find a trustworthy repair shop and take it there.
Sep 05, 2012 | Televison & Video
Sounds like a Tab Issue,Connections are Become Bad on the Inner Connections to the Screen,The Real Fix would be to Replace The Panel
Dec 30, 2011 | JVC LT-37X688 37 in. LCD HDTV
Poloroid 42" lcd - high pitched sound from the
That HDMI port is shorted and dying.Just don't used that HDMI port.That the cheapest and easy way,just by pass that HDMI port.Other wise than u have to spend like $130 -150 to buy a whole refurbish tv Tuner signal board for the replacement.Because those HDMI ports,dosen't have any indiviual sell by itself as HDMI port as part.
Nov 15, 2010 | Polaroid TDX-03211C LCD TV
Dynex 37" LCD TV bad color
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
Oct 26, 2009 | Dynex DX-LCD37 TV
High pitched squeal
Hello, This sounds as if it could be a switching power supply problem or a ballast problem. Both will effect your power supply and cause malfunction in various subsystems (audio, screen control, control systems, and the like). I would suggest having a qualified TV repair technician look at the set. This is because there are no user servicable parts associated with this type of problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Buzzing sound after only 2-1/2 years of service
I suspect you have a bad set of capacitors in the control module. This problem usually starts out as a high pitched noise but can lead to the TV not turning on. Please see the link below, posted by StivO. It gives step by step instructions on how to replace the capacitors. This is a very inexpensive fix.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Apr 13, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
"clouds" on 32" Samsung tv screen
My best suggestion is to replace the inverter to the lcd panel.I could look up the part number if you need.Let me know - edcarson
Feb 18, 2008 | Samsung TXM3281HF 32" TV
Sound problem
sounds like a fan issue that would be myfirst guess
Mar 21, 2007 | LG RZ-37LZ30 37 in. LCD Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
222 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
