I just install the backup camera in my 2010 ford ranger sport and the ouku radio 2 din ,but when i'm going reverse the camera is not turning ON automaticly, i have to turn it ON manually in the setup off the radio Can you tell me what can i do to fix the problem ?
Above is true. There is a camera wire that needs to be hooked up to the reverse indicator wire. You can tap into the wire in the wires harness under your dash but if you cannot find it then run it back to your reverse light in your taillight housing wore harness.
Connect the power wire to the back up lites so when the transmission is in reverse the camera will come on.
know already done the camera function very well Limited Time Offer know that the radio does not automatically change the screen in the radio I must manually change
