Question about Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Broken ac outlet from board. where do i get parts?
The outlet where the ac adapter plugs into broke off the board ( the prongs broke). The scanner will not work on batteries either. Where can I get a part for this so that I can re-solder it to the board?
Found a part at a local store and soldered it to the board.
Posted on Jun 06, 2009
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
Feb 16, 2014 | Frigidaire Washing Machines
Ac adapter broke
Buy a RIM Blackberry Rapid Charger. It uses another connection:the one with the three magnetic contacts.
It was about $10 on amazon today. And it charges fast.
Feb 24, 2013 | RIM Blackberry Ac Adapter 5 V Dc 1.80 A...
I bought a deckcell universal laptop charger. The product I received, has a plug that does not fit into a standard wall outlet. The two prongs that come out of the plug have a unconventional shape and...
If the prongs are shaped incorrectly then you might have a European model (or if you are in Europe then you might have an American Model). The AC adapter (the big block) should be rated for use in North America and Europe (input 100V - 240V) so you might just need to replace the plug half of the laptop charger. It might just be easier to contact the seller and ask them to send the correct plug for you AC Adapter.
Please rate if this helps.
P.S if you have any other appliance with a different prongs coming off the plug DO NOT PLUG IT IN!!! laptops chargers are ok because they are built to work in different voltages.
Mar 15, 2011 | Computers & Internet
Battery does not hold charge and pc shuts down even when plugged to ac outlet.
your ac adapter is dead or the adapters connnection is broken from the main board
Jan 18, 2011 | ASUS Eee Atom Z520 Netbook
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
My laptop emachines e510 an my problem is that when i plug my recharger he don`t want to turn on and with the battery it`s the same!!! also when i plug the charger i listen a some sound like buzz!!! can...
Most likely the AC Adapter has a short in either the cord or the black box which contains the board which converts the power from your home outlet to 12V or 19V which the laptop motherboard uses. This would cause thebuzz or hum coming from it. I suggest getting a replacement AC Adapter and see if it fixes the issue. The other thing that could be causing this is that the DC Jack that you are plugging the adapter into, could be broken. Most of these jacks have 3 prongs that are soldered onto your motherboard and if any of them break and lose contact to the motherboard it will result in your battery not charging and possible feedback to the AC Adapter. If that is the case then it can usually be repaired at a PC Repair store or Electronics Repair store for around $200. Let me know if this fixes your issue.
Aug 10, 2010 | eMachines eMD620-5133 Notebook
Gets dark wave in three waves,
The first thing I would suspect is a noisy AC supply. Try using a ground adaptor. Sounds technical, but if you every went to Grandpa's he may have been using a few and you just didn't know what they were. They are commonly used to adapt a 3 prong electrical plug to a 2 prong AC outlet. If your TV does have a 3 prong AC cord, give this a try before you do anything. It's a cheap solution and often works like a charm.
Mar 17, 2010 | Vizio Televison & Video
Adapter prong is broken on mmmmy wall outlet for my security camera. It broke when I tried to plug it into an extention cord. Only one of the prongs are broken.
You can try using an apoxy metal based resin to glue it back into place... or if you can access it properly solder the prong back in place...
If neither of these help - then I am afraid you need to replace your wall outlet
Oct 02, 2009 | Computers & Internet
Is there an adapter for a 4-prong plug to fit a 3-prong 220
they dont sell adapters like that..you have to change the cord and it wont hurt the dryer at all
Jan 29, 2009 | Maytag PYE2300AY Electric Dryer
Nintendo dslite wont turn on.tried charging it wit 3 different charges and it still wont charge
Ensure that you are properly recharging the battery.
1. Insert the small end of the adapter into the external extension connector (labeled "5.2V=IN") on the back of the Nintendo DS Lite, just next to the SLOT 1 Game Card opening.
2. Swing the prongs on the AC adapter until they lock into place, then insert it into a standard (120 volt) outlet.
The plug should be mounted vertically or on a floor outlet (such as a power strip).
3. Once the adapter is properly inserted, the unit will begin to charge (the orange charging light will display).
4. Once the DS Lite is fully charged, the orange charge light will go off.
Check the AC Adapter for damage (such as bent prongs or split wires). If you see damage to the AC Adapter, purchase a replacement from Nintendos Online Store.
Try plugging the AC Adapter into another wall outlet. Its possible the outlet is not working properly and has not been charging the Nintendo DS Lite.
If you are unable to get power to your Nintendo DS Lite, despite trying to properly recharge the unit, then your system will need to be repaired.
Nintendo offers convenient repairs, fast turnaround times and, for all systems repaired, a new one-year manufacturer's warranty.
Jul 14, 2008 | Nintendo DS Lite Console
Uniden BC60XLT-1 (30 Channels) 2-Way Radio Logo
96 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
