Question about Bowflex Treadclimber
Calibration fail message on bowflex treadclimber.....help
I just put my treadclimber together. i stupidly didn't calibrate it first, and was getting the "L 5" error. then i attempted to calibrate it and now the message is "calibration fail". i've tried to calibrate numerous times since then.
someone please help.
  • Anonymous Mar 30, 2014
    Getting "EStP" warning every time I try to use TC10. I have the safety key in place. I have wiped the bottom of the key off with water and soft cloth to make sure that it is clean. I have unplugged machine several times, turned it back on, positioned safety key and pressed start button but the same message keeps popping up. I am not sure what to do next.
    Problem Solver:
  • 6 Answers
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
Bowflex treadclimber gives error code h13 h24
this a problem with a bad design from a factory. You must call to service support a explain this error. Is a problem,with a PROM AND EPROM.
However you can try to RUN the software calibration for diagnose, and troubleshootingl.
God bless you
May 09, 2012 | Bowflex Treadclimber
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
My bowflex treadclimber starts for abut 3sec then err L5 shows on the screen PLEASE HELP!
The machine needs to be re-calibrated if its an L5 error.
Your speed sensor must have been damaged either during shipping or use. You'll need a new one. If under warranty - give Bowflex a call. They will ship you out a new sensor and guide you through installing it via the phone... re-calibrating the machine... and getting it operational again. It will take about 2 hours.
Jan 22, 2011 | Bowflex Treadclimber
Fails calibration
Contact support at Treadclimber.com. They will walk you through troubleshooting steps.
Aug 28, 2010 | Bowflex Treadclimber
Can't get Bowflex TreadClimber TC5000 to pass calibration.
DEAR
AT FIRST YOU MUST REMOVE COVER AND SEE CAREFULLY TO FIND SENSORS SOME SENSORS ARE PHOTO SENSOR AND GET ON DUST AND CAN NOT GOOD WORK THEN BETTER THIS IS YOU CLEAN DUST VERY VERY GOOD PERHAPS SOLVE YOUR PROBLEM.
you can countiue contact us with smart phone on wattsapp or telegram by :
+989195116738
Mar 29, 2017 | Bowflex Treadclimber
I am having trouble with my Bowflex TC5000. The calibrations is failing. The treads aren't moving but the monitor is trying to calibrate.
The motor must move the drive pulley for calibration to pass. remove rear covers and check drive belt. you should hear the lwr board relay click to engage the motor. if you hear it and the motor does not move and you have checked the belt then you need to test the motor. Typically remove the belt and turn by hand...it should be very smooth and spin freely. If not replace the motor. Direct 9 volts to the motor leads unplugged from the board will tell you if the motor is good. be careful as capacitors are present and risk of shock is always possible. capacitors stay charged for about 10 mins after unit is unplugged
Jul 30, 2009 | Bowflex Treadclimber
Bowflex Treadclimber Calibration Failed
Check the wire connection at the bottom of the right upright. Male Female white connectors. if they are good then check speed sensor under the left rear treadle. Must be about credit card distance from drive pulley. Remove rear covers to access. Note you will have to remove both side covers and back cover. 10 Screws.
Jun 23, 2009 | Bowflex Treadclimber
Calibration Failed
make sure speed sensor isnt to far away from left wheel or did not get unplugged from circut board
Dec 25, 2008 | Bowflex TC3000 Treadclimber
My bowflex tc5000 will not calibrate
Check the speed sensor and make sure it is no farther than a credit card away from the drive pully. Unplug unit Located...remove left and right rear covers and back cover. 3 screws in each and 4 screws in back. Follow 2 black wires up to drive belt pulley under back of left treadle. slide sensor in with cc between it and the pully. Recalibrate
Dec 07, 2008 | Bowflex Treadclimber TC5300
Bowflex Treadclimber Logo
1,824 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
