Question about JVC SR-MV40 DVD Recorder/VCR
Finalization of Disks
What causes a disk not to finalize after recording?  I am a video court reporter and record depositions directly to disk and on more than one occassion the disk fails to finalize.
Is this machine only capable of lasting about 9 months and recording about 300 disks. What is the problem and how can it be corrected so it doesn't happen in the future?
  • John Hank Oct 24, 2007
    It is the JVC SR-MV40 model
    Problem Solver:
  • 5 Answers
Failing to Finalize and thus making the DVD 'playable' on other DVD Players is most often caused by the media (your blank disk), not the Recorder. Trying another disk, from the same 'stack' or manufacturer will often have the same result. But, it is a 'hit and miss' situation. As you have the recording on the hard drive it can be worth your while connecting another basic DVD Recorder to input the material to a disk in that recorder. Sounds silly perhaps, but I have actually done this - and had the disk finalized in the second unit.
Posted on Jan 28, 2008
SOURCE:
I have a Philips 615 DVD recorder that has worked wonderfully since I got it in 2005. However, this weekend it decided to stop reading any DVD put into the tray. I was recording something and finalized it....
Sometimes a blank DVD will not be the proper format. Upgrades have been done to DVD-R disks, and your recorder might not recognize the upgraded format on the newer disks. This has happened with Philips, Emerson machines- they all use a Funai burner. I have found with my FUNAI/Philips/Emerson recorder that purchasing the Philips, 1-16 speed DVD-R blank disks fixes this problem on my 2 machines. If you have an older DVD-RW 2 speed disk, it should work as well.
Jul 01, 2017 | Televison & Video
My Sony DVD GX210 fails to finalize my recorded disk. I have recorded it using a DVD + R disk which is compatible with the machine for recording, however when i go to finalize the disk, it comes up as...
Might just be that disc. Have you tried another? Maybe try doing that and then see what happens. If it happens again, try another machine. If it works in the other one, you'll need to replace your burner.
Jan 07, 2018 | Sony RDRGX210S DVD Recorder
How do i transfer recording from vhs to dvd ram panasonic
The easiest way to transfer from VHS to DVD is by connecting the VHS player (or VCR) A/V OUT to the DVD recorder A/V IN. This uses inexpensive RCA cables, which can often be found in a local "dollar store" or for around 5 dollars in any electronics store.
The jacks are round and colored Yellow (Video), Red (Audio Right), and White (Audio Left).
After you connect the A/V OUT from your VHS player to your DVD recorder A/V IN, you will need to select the INPUT of your DVD recorder to "A/V" or "composite" in the SETUP menu. Your DVD recorder manual will provide details for your specific model on how to select the A/V input.
Once the correct input is selected, press PLAY on your VHS player, and as soon as the picture is steady, press RECORD on your DVD recorder. You will be good to go!
I recommend that you do not use DVD-RAM disks, though. They are "platform specific", meaning that if your DVD-RAM burner dies, you will need to replace it with the same model to be able to view your video. The best solution that I have found is to use blank DVD-R disks. They are much less expensive than DVD-RAM media. Make sure that after you are done recording on a disk that you "finalize" it. Until any DVD is finalized, it will be "platform specific"- by finalizing the disk, it will work on any DVD player. Check your DVD burner manual for the details on how to finalize disks.... the procedure varies from one manufacturer to another.
DVD-RAM and DVD+/- RW disks have a drawback in that before they can be used at all, they need to be formatted. Depending on the make and model of your burner, this can take up to 45 minutes. The big advantage with DVD-RAM and DVD+/-RW is that they can be erased and reused. DVD+/-R media is "record once".... you cannot erase and reuse them, but they are much less expensive.
DVD+R and DVD-R disks can be written to directly, then finalized as I described above.
My experience has been that for videos, DVD-R disks produce the best results, and have the least amount of errors. The disk brands that I have had the best luck with are TDK and Panasonic. Each manufacturer uses a different dye recipe for their disks, and some may not work at all for you. Keep away from the generic disks unless you are willing to experiment. I have had allot of problems with DVD+R so I no longer use them.
I Hope this was not TMI..... I just wanted to convey as much as I could so your recording experiences are pleasant ones..... Good Luck, and Thank You for using FixYa!
May 25, 2011 | Panasonic Televison & Video
I cannot play burned dvd's from this system in other dvd players becahse I cannot finalize the dvd. How do I finalize?
The recording may have used all the media on the disk because you let it run until it was full.
Now, there is no room to finalize the disk.
Play this back on the machine where it was recorded while recording it to another DVD recorder..
This time, BE THERE to stop the recording.
Set the recorder to a speed that leaves at least 10 minutes extra space for finalization.
Jan 31, 2011 | Pioneer DVR-RT500 DVD Recorder/VCR
About 5 years ago I transfered some vhs tapes to dvd using a go video vr 3840. I did not finalize the dvd's. I need to buy another vr 3840 to finalize the dvd's. Where can I find one to buy?
You should not need another '3840 to finalize the disks. Finalization just ends the index, makes writing back to the disk near impossible. You should be able to finalize / close the disk using a dvd authoring program (Nero, CD BurnerXP, etc).
The catch may be that the disks that you created are formatted as DVD video, closing a video disk may not be the same.
Another possibility is to use an authoring program (like the above) to copy your un-finalized disks to fresh media, and specify the disks to be finalized (or closed) when completed. I would try this first, the only thing to lose is time, and a disk. Oh, and about 4.7GB of hard disk space to create the image if you only have 1 DVD drive.
Jun 29, 2010 | GoVideo Go Video VR3840 DVD Recorder/VCR
Can't play recorded DVD's(from philips 3505) on other dvd players
Hi I am Vortash It very much sounds like you are not finalizing your disks .. any dvd recorder that makes a disc from computer dvd's to free standing unit s work on the same software principle , however the programs do differ slightly and finalisation stanard izes the disc to run on any player, without it another recorder will either not recognize the disk or the language it is written in . Read that message at the end and you will see the option to finalize or it will say do you wish to be able to play this on another dvd or it will do it automatically if you set it to do so in the menu on some sets .
if your player isnt doing this it is not set to do so in the menu settings disks can be finalized at any time after recording providing they are not over filled as the finalization process will take up at least 10-12 mb some do it in more some might do it in less depending on the software hope this helps Regards vortash
May 17, 2009 | Philips DVDR3505/37 DVD Recorder
Panasonic DVD Recorder
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Sep 07, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Dvd recorded movies will not play on my other dvd players
Before removing the DVD from the recorder, it must go through a process called finalization. Once you finalize the discs, then it will be able to be seen on most DVD players. Check your recorder's documentation on how to finalize your discs.
Jun 23, 2008 | HP Pavilion zd8000 Notebook
Finalization problem2
After transfering video from HD to DVD, before you press the "Menu" button. please make sure you you press "DVD" button on your remote to tell the machine you want the menu for "DVD" first.
It confused me at first :-)
Hope this helped
Feb 11, 2008 | LG RH266 Recorder
Recorded disc playback trouble
You have to finalize the dvd's through the menu... from page 36 of the manual....on the remote control press SETUP use the arrow key to select "DISC EDIT" press OK Use the arrow key to select FINALIZE press OK. A confirmation window appears, use the arrow to select YES and press OK.
Jan 16, 2008 | Philips Magnavox MWR10D6 DVD Recorder
JVC SR-MV40 DVD Recorder/VCR Logo
362 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
