Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
Well i replaced the fuel line which i can only order the exsisting stihl fuel line cant get and ordanary line made cuase its made different had to order one and changed fuel filter and shes all good and what really helped was ther is a low and high mixture screw and the low seems to help stop the chain from goin,the low idle went down to so seems like it was off of its low setting but seems to be doin good have to take the saw on a camping trip and see how it does but should be fine. Thx for ur help clintgonemad :)
  • kody_conn Jun 05, 2009
    Again sorry if im not making sense first time using this site ill repeat the soulution I found. well i replaced the fuel line which i can only order the exsisting stihl fuel line cant get and ordanary line made cuase its made different had to order one and changed fuel filter and shes all good and what really helped was ther is a low and high mixture screw and the low seems to help stop the chain from goin,the low idle went down to so seems like it was off of its low setting but seems to be doin good have to take the saw on a camping trip and see how it does but should be fine. Thx for ur help clintgonemad :)
  • kody_conn Jun 07, 2009
    Sorry steve_lima lol im getting screwed up here yah i meant to put my saw under Stihl but i know that ther 2 different saws just signed up for the site a few weeks ago at first and wanted to get the problem of saw out ther right away and didnt pay attention to what the modle of my saw said on the problem title. Sorry for the mix up ther.
  • 181 Answers
Are you working on a stihl saw or husqvarna saw.they are two differant types of saws.let me know what you are working on and i'll be glad to help you out.................
Posted on Jun 06, 2009
How do you replace the fuel lines on a Stihl chainsaw electronic quick stop 009L?
Hey Doug,
Replacing the fuel line is a pain.. not hard.. just time consuming and requires some disassembly.. TAKE PICTURES OF ALL PHASES OF DISASSEMBLY....From the Stihl's I worked on, you have to remove the air filter, the carburetor, most of the covers.. when you get to the fuel tank.. just remove the line with needle nose pliers..reinstall everything according to the pictures... Good luck..
Aug 30, 2017 | Stihl Garden
Stihl ts 420 run fine idles good but on half choke changed filter replace line repace carbureator cut off when switch is placed in no choke position what could be the problem
need to know which filter was replaced, air or fuel? Also, is saw being used at different elevation than when it ran ok?
Aug 26, 2017 | Stihl Saws
How do I replace the Stihl BR400 backpack leaf blower fuel pickup body and fuel line?
remove the fuel tank is the easiest way... but to change the fuel lines to the carb you have to remove it as well
Oct 26, 2014 | Stihl BR400 Backpack Leaf Blower
Stihl 300 blower not getting up to speed
First check the exhaust screen for clogging. If not clogged then the unit is lean. Check the fuel filter. Check the fuel line coming out of the tank for cracks. An adjustment may cure the problem if not then a carb rebuild is in order.
Aug 31, 2014 | Stihl Garden
Stihl 012 av fuel lines
The 2nd line might be a vapor return line back to the fuel tank? I've dealt more with repairing bigger saws more than smaller ones. You should go to a Stihl shop&take a look at chainsaws about the same size as yours&take off the air filter cover&look to see where the carburetor lines go.
Aug 01, 2014 | Stihl 011avt Brake Handle 009 010 011 012...
I pulled the fuel filter out of my stihl 45 but the fuel line didnt come with it. How do I get the fuel line out.
it has to be removed from the top of tank. it has a gromit also they may come as one part in which case you just replace them.
Oct 02, 2012 | Stihl String Trimmer Air Filter 45 55...
Stihl FS40 Runs for 60 secs at low RPM with the trigger fully depressed - then quits
had the same problem.
in the fuel tank is a gas filter and a fuel line. replace both.
the line gets soft with age and collapse and restricts fuel flow.
while u are at it replace the other two fuel lines as well. easy to get to when u have the cover off.
Aug 10, 2009 | Oregon Scientific Complete Carburetor for...
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Dec 20, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
121 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
