Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Smokes for short intervals then stops - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • ed in oregon May 11, 2010
    more info please - what smokes for short intervals then stops, the engine? the belts? what kind of smoke? brand of engine? model number?
  • 40 Answers
Check your oil level. When oil level is excessively high that's a usual symptom. Drain any excess oil (in an adequate container) and problem will dissappear after a few minutes running. I hope you find this solution helpful. Please rate it and thanks for using Fixya. Good luck!
Posted on Nov 05, 2009
My 96 lexus ls400 smokes on opposite side of location of battery/fuses while battery is connected
you must have a wire shorting out look for a bare spot of wire near the smoke
Jul 07, 2012 | 1996 Lexus ES 300
I have a 2001 Chevy Impala 3.8 V-6 and it is using a quart of oil every 800 miles or so. The PCV valve has been replaced, but I fear that the next service visit will result in a much bigger bill. Help...
If you have no leaks, it will be an internal issue that can only be expensive-valve seals (smokes when cold or at start up) or rings (smokes on acceleration, eventually may have issues with catalytic converter)-You are probably using 5W-30 weight oil, consider going to 10W-40 or throw in an occasional bottle of 'stop smoke' additive-while not great, 800 miles per quart is not a disaster (yet) and as long as you change your oil at set intervals (3000 miles or less), don't overheat it, and don't beat on it when cold, it should last many, many more miles.
Jan 23, 2011 | Chevrolet Impala Cars & Trucks
Alternator smokes on my 1990 jetta when i hook up the negative terminal
Internal short in alternator.
Possible small nut or washer dropped into vents. Also could be regulator on back held in with two screws shorting across slip rings.
Once the smoke has escaped from any electrical devise it stops working. : )
Check the battery connections again to make sure they are positive to positive, negative to negative.
Jan 15, 2011 | 1990 Volkswagen Jetta
I am about to buy jetta petrol 1999 review model which is has 225 k on it. what are the main issues i have to check before finalizing the deal????
A lot of miles on this beast. check carefully and unless a REAL bargain...walk away.
Timing Belt replacement ....When and who? Every 100,000 miles is service interval.
Reason why they are selling it...... Problems or just getting a newer car ?.
Smokes on start up cold?
Smokes warm idling ?
Smokes after coast down and then accelerating ?
Warm start okay ?
Drive shaft boots not split ?
Does transmission jump out of any gear?
General condition ie: accident damage, tyre wear even, tested recently ?
Brakes stop car without pulling to one side.
Does car drift off center along a straight road above 30 mph?
Seat belts operate ?
Steering gear loose or worn? Must be less than 5mm free play side to side on steering wheel at 12 o'clock..
Steering wheel solid mounted...lower support bearing okay ? They drop out around the steering shaft.
All lights work including high and low beam?
Brake lamps working?
Windshield free of cracks and chips and not scored by old wipers.
Pull up carpet and inspect for corrosion in floor pan and in trunk ( boot.)
Jan 14, 2011 | 1999 Volkswagen Jetta
It smokes then clears up then smokes again could it be a sensor??
Check for worn valve guides & seals. Make sure PCV is functioning as well, but it sounds like guides worn.
Sep 30, 2009 | 1987 Ford Ranger
Intermittantly for short intervals while running
Make sure you replace the fuel and air filter.
Sep 03, 2009 | 1997 Buick LeSabre
Clicking noise, PLEASE HELP!!! PLEASE!!!
That happend to me. All i did was move the piece that holds the laser right down by the part that holds the disc and it worked fine then..
Jul 12, 2008 | Sony PlayStation 2 Slimline Console
Sony KP-57WV600
· 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
Mar 26, 2008 | Sony KP-57WV600 57" Rear Projection...
GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
111 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
