Question about Jenn-Air JES9860 Electric Kitchen Range
CFM's pushed out by blower for jennair S176W range
I need to know how much air is being pushed out by the downdraft blower attached to my s176W Jennair range
  • defolter Jun 04, 2009
    I understand that there is a range of CFM's but I need to know the exact CFM's for my Jenn-Air model S176W . This unit was installed back in 1995.
  • 132 Answers
There is a 500 cfm blower spec for that moddel that i found hope this helps.
Posted on Jun 05, 2009
    Brigadier General:
  • 3,614 Answers
initially downdraft ranges from 6oo CFm to 1600 CFM within the pushbutton control.
CFM means (cubic feet of evacuated air per minute)
Hope this initial info/idea helps.
Let me know for further clarifications,
Posted on Jun 04, 2009
I have s176w jennair range that flashes and F1 signal and a makes a buzzing sound when I turn any burners on
F1 usually go back to the electronic control board. Unplug and replug the power back on. If error code comes back, replace board.
You might want to check all wires going to the board for anything unusual...make sure they are properly attached etc.
Oct 23, 2013 | Jenn-Air Kitchen Ranges
S176 keypad replacement
call chas&son,s at 579-379-0993 and they will come out the same day no less okay
Oct 06, 2012 | Jenn-Air S176w Electric Downdraft Range...
My jenn air s176w oven control buttons are not working. No response at all.
Hello & Welcome to FixYa
It indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Oct 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
My jenn air s176w-c is not working it continiously beeps and a error code of f0 appears on the screen
Hi
Error code F0 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Model S176W Jenn-air F-1 code flashing and beeping
Not sure what an F1 code is on that unit, but an easy check here,
shut off unit at breaker, remove face and unhook touchpad (ribbon) from the ERC. Turn the breaker back on, If the error code stops and it doesn't beep, the touchpad is most likely the problem. If it continues to beep and throw code, could be the Erc, (or something else telling the erc somethings wrong.) without knowing the F1 fault code, I wouldnt know where to start looking!
I would probably recommend a tech to reinstall the new Erc and or touchpad. Most new electrical components require extreme care when handling/installing, and a tech will know the proper procedures. Good Luck!
Sep 12, 2009 | Jenn-Air JGS8750 Gas Kitchen Range
Jenn-air model s176w-c oven
You have a fault in the controller module. I suspect a bad power supply capacitor is feeding dirty voltage to the control electronics.
Unplug the range, then open the control panel (usually you get into it from the back). Remove the control module (warning: handle it only by the edges to prevent damaging the circuitry with static electricity from your fingers). You may not have to disconnect everything at this point; you just need to see the component side. Look for any electrolytic capacitors that have a domed top instead of a flat top. Normal is flat top; domed capacitors are burned out. Also, if you see a smaller electrolytic capacitor that has obviously had its can enclosure pushed off the base, that would be bad. See the photo for a comparison of bad (marked with red boxes) vs. good capacitors.
These capacitors are relatively inexpensive to replace, usually less than $1.50 US from on-line sources. I recommend using the Panasonic FR series as the most reliable replacements. It should be much cheaper to pay a TV technician to put in the parts than to buy a replacement controller. Note: if this is what you find, and you want to take the module out for service, first go to a computer parts store and beg an anti-static bag from them. Make sure it's big enough to hold the controller including the keypad (keypad connectors can be tricky; if you don't know how the latch on the connector works you can damage the connector or keypad cable, so leave it attached and let your technician worry about it). I don't have the service info for your model, so I wouldn't know what kind of latch it uses without seeing it. Again, handling the module only by the circuit board edges or whatever mounting frame it is in, place it in the antistatic bag for transport. DO NOT USE AN ORDINARY PLASTIC BAG; these generate static charges instead of protecting from them.
Jul 10, 2017 | Jenn-Air Ovens
I wanted to know how many Jennair downdraft electric ranges were out in 2000, with a sealed 2 unit burner and a grill and are there still replaceable plug in units for them?
Modules are still available for some models but you need the model and serial numbers of the range to find out what is available to fit it. The customer service number for Jenn-air is
800-536-6847. You might call a local appliance store if they carry Jenn-air products.
Jan 01, 2009 | Kitchen Ranges
Downdraft
I would double check that the installer used the correct vent hood outside. The correct one has a spring that keeps the outdoor flap closed when not in use. Cleaning the outdoor flap area may also help it seal a little better. Even if the right hood was installed, you might check to see there is a spring present (or signs that there was one.
I have never had air blow out the downdraft, but I do feel cold travel to the fan unit which makes the floor cold in front of the range.
Jul 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Jenn-Air JES9860 Electric Kitchen Range Logo
618 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
