Question about Kodak EasyShare C533 Digital Camera
No sound when making a video
I have no sound at all when I am making a video.  We have tried using the volume arrows but nothing happens.  Please advise.
  • Anonymous Feb 13, 2008
    i tried all the steps can you give an idea how to put sound?
I had the same problem so i called the place and they said when you take a video on your camera you wont hear any sound but when you put it on the computer you do.
Posted on Dec 18, 2007
No sound when recording a video
in menu, you will sele sound memo, and adjust the volume.when your record your must press func/set button, you will get sound.
read your owner manual very well.
God bless you
Sep 27, 2012 | Kodak EasyShare V1003 Digital Camera
My Casio EX-H30 video sound not coming please if some one knows about it
-try to simultaneosly press the up directional arrow while playing videos
-up and down arrow controls volume during video playback in your camera
tip: avoid blocking the microphone on top of the camera during recording. (small pinhole on top of the camera)
Jun 05, 2011 | Casio EXILIM EX-H30 Digital Camera
When i am making a phone call or receiving one, i can't hear the person on the other call because of low speaker volume. Need help urgently. When i play music it's fine but worse when receiving a call..
hi sir..!
nothing to worry!
move to menu on ur phone and try to change the profile that u r using current hit the option and move to personalise and under this option try to maximize the sound volume...!
then another way is wen ur r in call try to hit right arrow key to maximise the volume..!
thank u!
Mar 09, 2011 | Nokia 5530 XpressMusic Smartphone
Using audio video jacks on my computer
Make sure you have the correct plug. The audio out is usually a green plug with a little picture of a speaker next to it. The microphone jack is usually red with, you guessed it, a little picture of a microphone next to it. If you're trying to get sound from your PC to your stereo, you want to connect the cable to the green PC jack.
Also, make sure your volume on the PC isn't muted. In the lower right hand corner of your PC screen, you should see a little speaker icon (click the arrow next to the other icons if you don't see it). Double-click that speaker icon and look at the volume settings. Make sure nothing is muted or set too low, then try again.
Hope this helps.
Mar 05, 2010 | HP Compaq Presario SR2050NX PC Desktop
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
No audio on my Toshiba TV
Found this on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
Models: 20DL77, 20HLK67, 26HL47, 32HL17, 37HL17, 42HL17, 26HL37, 32HL37, 20HL67, 26HL67, 32HL67, 37HL67,
42HL167, 42HL67, 47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00128
1. Please check your connections and make sure if you are using COMPOSITE “yellow, white, and red cables”, SVIDEO,
with “white, and red” or Color Stream COMPONENT “green, blue, red, white and red cables,” that the white
and red cables which are used for audio are plugged in securely into the same inputs as the video.
If your connections are secure, the station may have broadcast difficulties. Try a different channel.
2. If you are using the coax cable from the wall, press the “ENTER” button on the middle of the remote. If the
information provided shows that you have SAP selected we will need to change it to STEREO or MONO. To do
this, we will need to press the “MENU” button, and use the RIGHT or LEFT arrow keys to highlight the AUDIO
menu. Next we will need to use the DOWN arrow to select AUDIO SETUP press “ENTER” and then arrow down to
MTS and use the RIGHT arrow to select stereo.
3. If you have a cable box or satellite receiver, please make sure the TV’s volume, as well as the box’s, volume is
turned up sufficiently.
4. The station may have broadcast difficulties. Try another channel.
5. The sound may be muted. Press VOLUME.
6. If you still have problems after following these steps please contact Customer Solutions at 1800-631-3811 Monday
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811.I hope this helps you with your problem.
Jan 14, 2009 | Toshiba 42HL167 42 in. LCD Television
No sound on my Toshiba Regza 42HL167
Found this troubleshooting method on the www.Toshiba.com website. Q. My TV has a picture, but there is no audio?
REF:FAQLCD00128
through Friday 8am to 7pm CST. The Toshiba customer service number is 1-800-631-3811. I hope this helps you with your problem.
Jan 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Volume
is easy just disable the AVS opcion en sound opcions
Sep 28, 2008 | Sony PlayStation Portable (PSP) Console
Audio works fine but voice doesn't
You need to reinstall driver of your sound and installed properly
Sep 22, 2008 | Dell Inspiron 6400 Notebook
One beep activated
Go to Settings > Sound > Volume > Master Volume > It should say "One Beep". Then press the right arrow button and it will change settings. Change it to the Level volume option. You should have your sound back.
Mar 17, 2008 | Lands Phones
Kodak EasyShare C533 Digital Camera Logo
43 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
