Question about Craftsman 25cc Gas Line Trimmer
Wheel line will not roatate
Engine runs fine but all of a sudden the wheeel where the line is no longer turns as if it got disengaged some way.
How do i disengae from four wheel drive
At best as I know the 2005 Prado is all time 4WD vehicle.
Is the engine running ? Can you shift the gears ?
May be something is broken in the drive train...
As a suggestion you can go home by locking the centre differential, proceeding at low speed and checking for noises .
Pls. let me know if it helps...
Apr 27, 2014 | 2005 Toyota LandCruiser Prado
Snowblower wheels will not move freely when drive is disengaged & and wheels will not turn when drive control engaged.
Check the drive shaft bushings if they are worn the gears are probably binding and this creates the problem you are having.
Feb 02, 2014 | Mtd Garden
08 f150 4x4 on front end only one side is disengaging when in 2 wheel drive. The problem is when engaged into 4x4 wheel drive the front drive line spins and both sides engage but only the back wheels spin...
If I read this correctly ( which I might not have, bit early for me ), the front drive shaft will engage ( from the transfer case ) but the front wheels are not engaged ?
If so, sounds like either the vacuum from the IWE ( Integrated Wheel End ) is not being released, or the IWEs have had an issue with part vacuum ( damage vacuum lines ) and the IWE gear is rounded off.
If you pull the vacuum lines at the IWEs ( there are 2 lines, 1 is the vacuum line, the other is the vent tube that routes up into the engine compartment and is not attached to anything ), the front wheel should engage ( might need a 5 * turn to mesh the gears ). With the vacuum lines off, jack up the front axle ( take precautions, chock the rear wheels, parking brake, jack stands, etc ) see if the front wheels are engaged ( turning one wheel should turn the other ). The option is to do this after the truck has sat over night, and the vacuum has been released out of the vacuum reservoir.
If the wheels turn correctly ( engaged ) I would think the contact plates in the transfer case are not making contact. Good starting point for this is the connector on the side of the transfer case, some times this gets gummed up, and the pins do not make good contact. The contact plates in the transfer case are used for a few things, one of them is to signal the IWE solenoids to release vacuum to the IWEs.
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vacuum is removed the spring engages the IWE.
Here is a black diagram of the IWE vacuum system
Feb 05, 2011 | 2004 Ford F150
Wont disengage out of 4 wheel drive 1998 ford ranger first time its stuck in 4 low we have backed up turned switch numerous times shut it off and restarted
Be sure to put the truck in neutral, while engine is running, while you disengage from 4 wheel drive (low) to 4 wheel drive (high) and then finally to 2 wheel drive. It is critical to shift transmission into neutral when switching out of 4WD Low, as indicated in your owner's manual. Hopefully, this will help to FixYa problem!
Oct 14, 2010 | 1998 Ford Ranger SuperCab
Tiptronic engage/disengage when hot
You clutch packs have worn out and the not shifting properly when hot confirms this, you may check transmission line pressure, hopefully I am wrong but most likely you need a total transmission rebuild. and a front wheel drive automatic is the most expensive rebuild out there.
May 25, 2009 | 2000 Honda Prelude
4 wheel drive enguage problem 89 Jeep
This system is run off a vacuum line get under the jeep its on the passenger side a hose runs into the axle housing make sure that it is plugged into the connector.
Jan 28, 2009 | 1989 Jeep Wrangler
How to replace rear wheel bearing on s type jaguar v reg
pretty basic the same and any other wheel bearing. But you need a hydraulic press, if you dont have one of those then their is just no way that you will be able to do it.
If it is newer than an 05 you need to take it to the dealership, because they need to hook up their computer and electronically disengage the rear parking brakes by putting it into service mode.
Jan 28, 2009 | 2001 Jaguar S-Type
Will my lamp still turn on if my color wheel needs replacing? How will I know if it is my color wheel or ballast that needs replacing??
If the color wheel doesn't start rotating or get up to the proper roatation speed then the lamp will never fire.
Jan 05, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Craftsman 25cc Gas Line Trimmer Logo
90 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
