Infocus sp50md need part digital board 510 2705 00 ?
    Sergeant:
    Champion:
  • 214 Answers
The thing you are asking for is a hardware item. so , if you had got the board with your infocus set than please install it. or else contact your dealer for the digital board......
Posted on Jun 03, 2009
Infocus LP130, Bulb fires then goes out
there is a problem with the power to the front fan from the main board. there are 3 wires going to the fans: one power, one return, and one signal. if the main board reads no signal from the fan's speed, it'll shut down. check the power going to the fans and the signal. you may need to replace the main board.
Mar 03, 2010 | InFocus Office Equipment & Supplies
I have two InFocus LP 540 projectors that simply do not indicate power when they are plugged in. Has anyone else experienced problems with the power supply? Is there a fuse somewhere that might need...
you can check the fuses (located on the power supply board where the cord plugs in), but it's more likely that the caps are dried out and need replacing, or the whole board itself. if that's the case, try av solutions in ny. they're an infocus service center and they're really good. www.avsolutionsny.com
Jan 22, 2010 | InFocus LP 540 Multimedia Projector
We have an InFocus L120 and the is a vertical line with a band of horizontal lines about three inches in width that flicker from the top to the bottom of the screen.
The connection between the main board and the dmd board might have some dust in the connection. If that doesn't work then your dmd board needs to be repaired or replaced. I do projector repairs if interested my ebay id is gtitubro
Jul 09, 2009 | InFocus Office Equipment & Supplies
Infocus x1a fan replacement
to remove the fan: remove the 8 screws from the bottom of the projector (4 silver, 4 inset and brass) and the 2 screws from the back. pull the back from the bottom, but use a small flat-head screwdriver to release the tabs seen through the topmost vent of the back. once off, unplug the speaker wires on the right and the cable harness on the left. pull the top off while pulling the front off from the bottom. remove the wire harnesses from the power supply board and the ground wire from the power input board. take the 4 screws off of the power input board and the 4 or 5 screws from the power supply board (and 1 center clip) and remove. take out the 4 or 5 screws from the metal shield and remove shield. now you can unplug the fan that need replacing and access the 2 screws holding the fan in. remove fan and replace with a like fan. since the fan speed is not monitored, if you can find one that's the same size, power, and plug size, use it. otherwise, contact an infocus service center and ask them for infocus part # 526-0192-00. reverse instructions to put it back together. but you must remove the front from the top case, put the top on first, plug the speaker and left harness in, then put the back and front on. wasn't that fun?
Jun 02, 2009 | InFocus X1A DLP Slide Projector
InFocus ScreenPlay SP61md10 (same as RCA HD61THW263)
I hope you are still under warranty. This is usually a problem with the main DLP chip seating properly on the board. I have rarely been able to correct this without getting a new engine board and DMD (digital mirror device).
Jul 15, 2008 | InFocus ScreenPlay 61" Rear Projection...
Hi there
I just sent you an email through fixya and I don't know if it went through but I was just saying about the fan and the grey bar. The problem with the fan, is not the fan itself, but the controller board not supplying enough voltage to the fan (you can see this by powering the fan on its own using a 6volt supply, you will fine that the fan will work perfectly normal), thus having to replace the entire control board at around $650+, this is a very common fault for these models. The grey bar as meantioned in my post is caused by the faulty light tunnel, there is a link I've posted here somewhere which tells you how to fix it, but you need extremely strong glue and electronics skills lol, otherwise infocus wouldn't sell me the part on its own, only the whole optical enigne at another $450+. Very poor service in regards to infocus.
Cheers
Rusteee
Apr 03, 2008 | InFocus X1A DLP Slide Projector
Loking for part # 265871 digital module (DM2) for Infocus screenplay61md10 hi def tv
We can rebuild your module for you.go to this link submit a email request and supply the make and model number as well as the part number for the module you need rebuilt and we will give you a quote for your board to be rebuilt all our rebuilt boards are fully guaranteed.
http://servicemanuals.vstore.ca/
Mar 31, 2008 | Televison & Video
LP540 INFOCUS
good luck. not even the infocus authorized service centers get those. besides, they were made by another company that does not make power supplies antmore. and infocus doesn't have any new ones in stock. if you're getting no power at all, replace the mosfets. it works half of the time.
Sep 20, 2007 | InFocus SP-LAMP-017 Projector Lamp for...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
