Question about Maytag Washing Machines
Heats up for 12 secs, then shuts off. Wont stay lit.
    Novelist:
  • 103 Answers
Dryers draw a lot of power...because of that, wiring and connectors get warm or hot and expand....eventually it causes loose connections and it starts to arc....you must open the back of the dryer and take a look at all the wires to see if you see any that are melted, black and so on....also check for loose connections where wires are bolted or screwed down...make sure everything is as tight as possible....and all connections are clean and have no burn marks or corrosion....it should work fine after that...And I WARN you now....unplug the dryer from the wall......If you do these checks and repairs with the plug still connected.....and it happens to short out on you...it could KILL you.....so UNPLUG the cord....good luck
silvio
Posted on Jun 03, 2009
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
Feb 15, 2011 | Heating & Cooling
Does not stay lit. It heats up, runs for a minute
You are having a common problem with gas grills. Click on my username and scroll down my profile to find my tips and tricks for trouble shooting common gas grill lighting issues. Hope one of them helps.
May 16, 2010 | Viking VGBQ410-3RT Grill
H500 wont go into pairing mode
are you holding the call button until the light stays lit/ That is about 6-10 sec and press find devices after it stays lit from your handset
Aug 15, 2009 | Motorola Mobility H500 Wireless Headset
Wont stay lit
flame sensor is probably dirty.remove and clean with fine steel wool.it is located near bottom of burner near ignitor
Aug 08, 2009 | Hayward H Series Pool & Spa Heater 200k...
Wont find headset
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
Jan 02, 2009 | Motorola Mobility HS810 Consumer Headset
Wont stay lit
when unit lights only runs 10 sec then shuts off
Oct 27, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
