Question about Philips 50PP9202 50" Rear Projection Television
Promblem with my tv
I can't get the color conversion right on my 2002 philips projection hd tv
  • Philips Master
  • 3,459 Answers
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips promblem with my tv - 0667c5f.png should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Posted on Jun 21, 2009
I have a Philips projection screen hd tv great picture but the color is way out off adjustment
see attached photo, it is a convergence problem.
If you have similar problem in customer menu is a way with the remote to adjust.
If it will not adjust there then the convergence chips are bad.
SD TECH
Oct 30, 2011 | Philips 60PP9202 60" Rear Projection...
Ihave a toshiba 43 inch hd 2002 rear projection the picture has shiffited to the right can I fix this
This tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows picture or 3D picture? The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,require changing to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 16, 2010 | Toshiba 51H84 51" Rear Projection...
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
I have a modle #5p5040 philips projection tv that has a strange colored picture when it is turned on whats my promblem
My problem with my projection LCD was the light engine went bad, it manifested itself with a growing blue haze that eventually washed over the entire screen. Luckily I got it fixed under warranty because it was a $2500 fix. The light engine is buried in the TV and needs a professional to align it.
Oct 01, 2009 | Televison & Video
My color wont line up it shows all 3 colors at once on the screen
Replce IC of convergance and check pheriparal componets on the convergence board
Sep 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
43'' HD projection philips tv color change
Check on ur auto covergence.Might have magnatics interference,the tv tech.use a dequasing coil to solve this prob.when it very bad,colors mast together.
Sep 12, 2009 | Philips 43PP9202 43" Rear Projection...
Blurry Philips TV model # 51PW936317F
The coolant will become congealed in Phillipd rear projections and the color will get very dim and hard to focus. You can get the coolant replace kit at the following link which contains the coolant for all 3 tubes and step by step instructions om CD. Heres a link to the kit.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-crt-coolant-replacement-kit/cName/repair-kits
Apr 25, 2009 | Televison & Video
Philips Projection TV the colors are separated- not converging
This was hapening to me too. To fix I just punched the tv. If this works then some wires were disconnected. Punch the right and left side not the screen or the back it will damage!
Apr 07, 2009 | Philips Televison & Video
Problem with HDTV on my Philips 55PP9401.
it is not reccommended for game console to be played on a projection t.v because projection tv's have three color bulbs in them and the conversion is different and if it happens to work it has been known to have burn the games image in the screen after awhile.. usually the store doesn't tell youthat unless you ask them about playing game consoles on a projection tv
Dec 01, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 42PF7320A/37
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
Philips 50PP9202 50" Rear Projection Television Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
