Question about Garden
?Fuel Pump? Engine will not start. If I spray fuel into breather it will run. I have changed fuel filter. Have gas. Does the fuel pump need a certain presure??This is a 27hp Kawasaki in a Exmart Z.
    Sergeant:
  • 353 Answers
Check the vacuum line from fuel pump to crank case may leak
Posted on Jun 20, 2009
How do I fix and 97 GMC 1/2 ton with a 350 vortec. Runs great once running. Sat for 5 years. If sits more than 5 minutes wont start without shot of starer fluid
have you changed the fuel filter and emptied the gas tank and put fresh gas in? Stale gas will not start as well as fresh gas and there could be water from condensation in the tank.
Mar 29, 2015 | 1997 GMC Sierra
Changed fuel filter and fuel pump. Sprayed with starter fluid and car will not start.
Are you certain you have fuel coming through? Best to check gas flow to make sure there is gas coming through lines. Did you change fuel pump with OEM or aftermarket? Electronic? All connections good and do you hear the fuel pump work? In my automotive life I have gotten a bad fuel pump before.
Also, not positive but I believe there are at least 2 fuel filters. I know my old Honda Civic had 3, so make sure you have identified where all fuel filters are.
Need more specifics regarding what kind of noise it is making, if any.
May 31, 2014 | 1999 Mazda MX-5 Miata
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Ran out of gas then filled up now car wont start. I have a 97 pontiac sunfire
The electric fuel pump located in the gas tank can and do burn out, from running out of gas. If it won't run, the fuel pressure will need to be checked to make certain it is the fuel pump. A fuel filter can get plugged and the motor will quit running, but you are sure that you ran out of gas?
Mar 16, 2011 | 1997 Pontiac Sunfire
Have a 1999 chevy s-10 pick-up. when i turn the key on i can hear the fuel pump (do not know how much pressure it it making) turn on, my engine turns over but it won't start. when i spray starting fluid in...
turn key on let pressure build up turn off than go to gas cap and open if hisses or burps pump is working change the fuel filter first than try restarting truck if still no fuel or starving than pump is week and may need replacing
Apr 08, 2010 | 1999 Chevrolet S-10 Pickup
92 oldsmobile cutlass ciera s 3.3 Will not stay started!!?
have fuel pressure tested pump may run but may not have enough pressure to activate injectors,also check timing chain or belt!!Best of Luck!!!!
Jun 24, 2009 | 1992 Oldsmobile Cutlass Ciera
Garden Logo
135 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
