Question about Dometic RM2652 Refrigerator
Will not cool on electricity
New rv owners dometic rm2652 will not work on electric mode, what to do we are really novice and have no clue how to begin to even start or where to look for where the problem may be. HELP!! Thank-You
  • steve
    steve May 11, 2010
    With a volt meter, make sure there is power at the 110 volt outlet.Set the meter for continuity and check the electric heater for ohms. No reading bad heater.Check power from the control board to the thermostat and back to the board, then to the electric heater.
  • 10,865 Answers
Hi there. There are actually a few causes of your problem but I would begin by checking the fuse. here is the Dometic troubleshooting manual for your model. It should help.
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Posted on Jun 04, 2009
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
I have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Jun 06, 2010 | Dometic RM2652 Refrigerator
Action 1: My RM2652 runs well on auto mode when its indicator's light is lit. Auto mode is an electric mode, right? Action 2: When I press on the "gas" button, the indicator's light next to the "auto"...
Auto mode is electric 1st then gas. If no 110v is available it tries to light the gas. Do you have gas & is it turned on? You should hear a clicking from the back of the frig. Make sure the air is purged out of the system by lighting your range and let the burners come on for 30 sec or so. You might have to cycle the frig on & off a couple of times after you purge the air. Set the button to "gas only".
Apr 01, 2010 | Dometic RM2652 Refrigerator
My Rm2652 Refrigerator in my Rv just quit cooling. The electric element checks good and heats as well as on gass. I did not smell any amonia odor from a leak and have not taken it out and turned it upside...
You need to have 12 volt supplied at all times to make it work
Check to be sure you have a good 12 + and a good ground.
Lots of times the coolant leaks without you smelling anything Slowly over time
Mar 06, 2010 | Dometic RM2652 Refrigerator
Have dometic fridge in rv.......new in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
911 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
