Question about Philips 9P5040C TV
Comes in small and green, fills out after warm-up
  • 80 Answers
The lasge signal board or "LSB" is going out. The problem comes from the power regulator not operating properly. The circuit board is no longer available as a new part, but tou can purchase a refubished one or send yours in to have it refurbished. Contact PTS corp at 1 800844 7871 and have your FULL model number. There are additional digits beyond the model number you have listed here.
Posted on Jun 03, 2009
Frigidaire Crown Washer #CRWS5700ASO won't fill with Hot or Warm water.
Clean small Filters...in THE WASHER Inletts.,Check for any clogging also.,inside THE HOSES.
Feb 21, 2013 | Frigidaire Washing Machines
How do i put coolant in my radiator
With the engine cold slowly remove the radiator cap and fill it to the top. Then check your reserve bottle. There are lines molded into your reserve bottle that tell you where to fill it to. You amy need a flashlight to see the lines. The bottle does not take much coolant...do not overfill it.
Nov 20, 2010 | 1997 Buick Skylark
How do i check the tranmission fluid in my car when it dont have a dip stick for it
underneath the car there is a small plug in the tranny. warm up car and go through the gears a few times. fill until fluid comes out. if fluid come out immediately. put the plug back in.
Aug 22, 2010 | 2004 Chevrolet Cavalier
Ice tray not filling
Open your freezer and remove the ice bin. You will see the mechanism and the tray that fills with water to make the cubes. On the left there should be a rocker switch that turns the ice maker on and off with a green light that tells you if its on or not, under the ice cobe tray there is a small paddle that should move, give it a wiggle. On the right you will see the wire for the ice maker, make sure that it is plugged in. Once the icemaker starts working (little green light comes on) you should have ice within 24 hours. You may need to remove the ice bin and a
small plastic louvered cover above it.
Hope this helps.
Jun 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
How do youo put freon in 99 ford expedition
Find your evaporator canister which will be toward the firewall. The low port is hard to see. You will need to buy yourself a re-fill kit which comes with the freon and gauge. Warm the engine and turn air cond. on. Attach the hose to your low port. Attach the can to the hose and turn the needle to pierce the top of the can. Be sure to turn the valve needle slowly to release the freon into the system. If the can starts to frost over, wrap a warm cloth around can to get the freon to flow easier. The kit will come with a gauge which will tell you if the system is already overcharged with problems or if the system needs freon. The one I have has yellow, blue, green, and red. The yellow is low, blue is good but the system could still use more depending on the psi, green is overcharged, and red is over charged with system problems, or other system problem.
May 15, 2010 | 1999 Ford Expedition
Heater will not blow hot air while truck is idle. When truck is moving hot air blows. There is some clear redish leakage underneth the truck. How can I fix this problem?
You are low on coolant. Find the leak, the red is most likely the coolant.
Coolant comes in 2 colors red and green.
Your leak is probably either a hole in a hose or a faulty water pump. The water pump has a small hole, usually on the bottom, when the seal goes bad, it will leak there. The only fix is a new water pump.
If it is a hose, just replace it. Make sure when you fill it that you fill the radiator and the overflow, just filling the overflow could cause it to over heat.
Also, depending on your climate, you need to mix your anti-freeze with 30-50% water. If you live in a very cold climate, you want to go with 30%water-70%anti-freeze.
Make sure that you use the right anti-freeze. red with red, green with green. Some green ones are now compatible with the red, if you change the color, make sure it is compatible.
Feb 18, 2010 | 2004 Dodge Ram 1500
RCA modelD52W20 Problems turning TV on when it is cold or for the first time after being off for an extended amount of time. The green lite comes on ,stays on a few seconds and goes out. After continueing...
well usually what works for me is a small heater on near the tv or just keeping the room above 65 degrees. There is a way on some tv's to turn off the power saver and that will keep your tv warm. But on others you cant turn it off so you have to deal with the heater or keeping the room warm cause that tv wont turn on for anything exept if its warm....
Dec 22, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
2003 Olds Silhouette - 83000 mi. Heater doesn't get as hot as it used to. The temp gauge shows two third the way to the center temp. It ran at this poing all summer after it was warmed up. My thinking is...
that could be the problem or it could be air in the stystem ....on top left of motor you will see a pipe that comes up.. on top is a small bleder screw .... remove radiator cap fill to top with antifreeze .... open bleder until just antifreeze comes out
Dec 27, 2008 | 1996 Oldsmobile Silhouette
Philips 9P5040C TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
