Question about Pioneer Audio Players & Recorders
Pioneer sx 737
Is it a big job to replace lamps in this unit.  Right now the fm stereo lamp is out and the meters are slightly dimmer than the rest of the unit.  I would like to get them all replaced.  If I was to take it to a tech what migt I expect to pay for this service or could I do it myself.  Myself being a maint tech for a cable Co for 27 yrs. Thankyou
Slinteriors
  • 8617 Answers
SOURCE: Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Apr 01, 2008
  • 4234 Answers
SOURCE: SX-950 Stereo Pioneer Receiver
The relay is a protection device for the speakers. It will shut off the speakers when problems are detected internally. I would suspect that some of the capacitors in the front end are in need of replacing. This is a common item for units this old. I have restored a number of these for customers over the years with much success. Figure about $15-$20 in parts for this repair plus the local labor rate. This unit is definately worth a refurb. What happens is that there is dsome DC voltage being leaked into the final amplification stage. This triggers the protection circuit to shut off the speakers. DC voltage on a speaker will heat up the coil and eventually destroy the speaker.
Dan
Posted on Apr 02, 2008
robotek
  • 1512 Answers
SOURCE: I just bought an old
Any luck with checking antenna connections? I have a service manual if you need it. Tuner section in this old girl predates the LM7001. Uses ha1137-38 chips, bit more complex to repair.
Posted on Jun 09, 2008
Santastinker
  • 4 Answers
SOURCE: Pioneer SX-737
You might try to get some information from: www.servicemanual.net. Somebody will need it if you want it worked on. If it is real heavy (40lb.s +) it may well be from the 70's. Mostly good units. I wouldn't give you $0.10 for their new stuff.
Posted on Nov 05, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
Meter fuse lamp 11/2 in 6.3 v 250 ma can not find one
http://www.ebay.com/itm/DYNACO-FISHER-MARANTZ-SANSUI-PIONEER-KENWOOD-JVC-OTHERS-HI-END-FUSE-LAMP-/370844118805?pt=US_Light_Bulbs&var=640100726899&hash=item5658082f15
Apr 18, 2013 | Harmon Kardon Vintage 70s Harman Kardon...
Put to big of a fuse in my pioneer sx-203 and burt out a cucit
Using a higher voltage fuse is not a problem, but if the fuse you used amps are to high, that is a problem. Sounds like a resister burnt. You have a short somewhere in that particular circuit, which is what took out your original fuse. . .your fuse did it's job by blowing and saving the circuit. If you can get your hands on a schematic, you can trace the circuit and find the short.
Jul 12, 2012 | Pioneer SX-205 Receiver
Short circuit ruined dimmer. need replaced ASAP
These can also be damaged by having the power applied during final connection... The inrush current from the cold lamp can blow the Triac in them, as well as a short circuit.
If you can replace the triac in the unit the rest is probably OK.
Feb 23, 2010 | Lightolier Electrical Supplies
All i can tell you is it is a Panasonic HDTV1080i . It tell me the lamp need replacing and the lamp meter needs rest.where is this and how do i replace and reset the meter
Howdy,
The Lamp is located on the right hand side of your TV.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Nov 16, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Miniature dial panel bulbs for Onkyo TX-2500 Mk II
Chances are they are LED. Check with Radio Shack or online you can check www.1000bulbs.com Hope this helps
Sep 21, 2009 | Audio Players & Recorders
Pioneer SX-737
My husband purchased his in 1975. Thirty-three years later is working fine.
Nov 04, 2008 | Pioneer Audio Players & Recorders
I just bought an old vintage pioneer sx 737 receiver and cannot get NO fm reception, and only 2 or 3 on am....HELP!!!!! I have used antennas as well...Charlie
Even with just a short wire, this model should be receiving a number of stations. Is there an IC inside marked LA7001 or something similar? If so, it is probably defective. This is a common failure. I'll look up your specific model later to confirm.
Dan
Jun 01, 2008 | Pioneer Audio Players & Recorders
108 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
