Electrolux EWFLS70JSS Washer Logo
A
Anonymous Posted on Jan 28, 2014
WONT GO INTO HIGH SPIN - Electrolux EWFLS70JSS Washer
1helpful
Commercial Washer Spin problem My Hwaesung Commercial Front load washer started making very loud noise on high spin RPM, now today won’t spin with large comforter load any suggestions? Works fine under...
You did not post the model number but when a front loader wont spin at high speed it usually means that a spring or shock absorber on the drum is broken or came off.
Front loader will spin in spin cycle but wont spin at high rpm needed to rinse water out of clothes
Possible that the controller is not shifting to switch on the high speed mode. Try and check if you can get this to work manually, try with another program on the panel. If so the fault is with the controller.
WHY WONT MY GENERAL ELECTRIC MODLE #WCXH208VOWW SPIN
Hi Darryl
Usually won't spin until water is drained to a low level.
Wont drain possibly because of blockage or pump blocked or stuck. (A Common Problem in Washing Machines)
So... As for further Troubleshooting
Process of elimination.
Where is Time Wheel set and what does it require to advanced to next stage.
Think of it as a Rotating Timer Switch stopping at each stage to check conditions.
The stages are controlled by sensors like "High Water Level"
The Sensor could be a simple Float Switch... eg. "High Water"
If water is High... Dont allow door to open and don't allow spin.
But do allow Pump to run.
It's all Plain Logic like used in computers (If, Then, Else)
Also Known AsTruth Tables
Good Luck
Truth Table Examples
MY MACHINE WONT SPIN
Check the voltage to the motor when the program goes to the spin cycle. If there is voltage then check for free movement and also check on the capacitor to the motor. In some cases the high speed coil winding to the motor for the high RPM spin cycle can be faulty.
Washing machine wont spin fast
If the motor has a twin speed check the high speed winding. If the washer has a gear box for high speed , check and see if the high speed is initiated while it is on high speed spin.
3helpful
Whirlpool 6th sense washing machine doesn't go into high spin
sounds like you have a blocked hose/pump vent hole.......if its holding water in the bottom of the tub it wont spin it will try but the pcb wont let it do the spin .due to pressure switch telling its got water left... pull pipe off pressure switch check holes not blocked check all hoses......
Hi my hotpoint washes but wont do a second spin,just had new door lock fitted
Most hotpoint machines can be a bit sensitive on the balance control. If you have a half full machine, somtimes it wount spin as high as you want. It will try some spins until it finishes without high spin.
Neptune wont spin
Looks like I may have to post this as a solution to get the link to you. I never tried to put a link in a clarification request.
Click on this Forum. If that doesn’t work here is the link to paste in your browser.
http://www.fixya.com/support/p46844-maytag_neptune_mlg2000a_front_load
Not going into high spin with any weight in it
I have had the same problem with my front loader. The rug is too heavy and the drum isn't balanced. Try adding more items to the wash and it will spin.
Top Electrolux Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
