Question about Hoover Elite U5061-900 Bagged Upright Vacuum
Hoover turbo power 1500 have part of bottom off to replace belt but can't find where to attach it? must be more parts to take off but how?
reddevil6
  • 1673 Answers
SOURCE: Hoover Self Propelled Wind Tunnel Turbo Powered 7600 The thin belt too loose
If this is a "V" belt, make sure the small roller that tightens the belt is ok and not jammed up. It may have to be replaced. Also if the flat belt is stretched at all, it won't work either.
Posted on Jan 06, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac clean surge turbo power 5200 attachment problems
That part to install in tank, is at the end of your hose. Take the lide off of the dirty water tank, on the front of the tank, there is a block that will slide out, then you can insert that part in its place. You have to have suction to make the brushes spin, so you just need to put the block on the end of the hose in the slot on the front of the tank. When down however, put that block you took out back, or your cleaner won't work right.
Posted on Jan 10, 2008
reddevil6
  • 1673 Answers
SOURCE: NEED TO REPLACE DRIVE BELT
Take off the brush roll cover, then take out the screws from the bottom to remove the top lid, the belt goes from the brush roll to the motor shaft.
Posted on Apr 20, 2008
SOURCE: Hoover 20.0 turbo power 4500
split or blocked hose
Posted on Jul 10, 2008
SOURCE: How do you put a Hoover runabout belt on vacuum
I found this on another site and it worked for me. RonL
Looking at the brush, remove the two screws from the black plate holding the brush. There are two clips that holds this plate once you remove the screws. This should be easy to remove with a flat type screw driver. Now is the tricky part to remove the top cover of the vacuum so you can access the compartment to put the belt on. The whole top part of this vacuum comes off. If you look above the part where black plate was, there are two more clips on the top left and top right hand corner. These two hold one end of the top cover. It is not as simple as pushing the clip to one end to slide out. You have to find a gap between the edge of top cover and bottom structure(right next to each clip) and shove the flat screw driver in and push the top cover away from the bottom structure and push down the top cover. You will notice that there are invisible hinges between the two which locks in the top cover.
Do the same procedure for the bottom right and left edges(right next to each end of the brush) of the vacuum and separate the two(bottom structure and top cover) out using the flat type screw driver..
Posted on Feb 02, 2009
How do I put on belt? cleaning lady took old one off so I'm lost. It's a hoover turbo 3000.
Assuming this is an upright vacuum, the belt is located under the bottom case and runs between the motor drive pin and round the brush or beater bar. After removing the screws to expose both of these pull up on bar, wrap belt around moter drive, replace idle side of bar, insert bar into belt and stretch to drop into place.
Mar 23, 2015 | Hoover Vacuums
Replace belt for Hoover Windtunnel Turbo Power U4645-930 Vacuum
Great Video Repair on the Replacement of the Hoover Windtunnel Self-Propelled Upright vacuum cleaners below. If you find the video helpful please be sure to rate it by clicking on the thumbs up icon below.
Thanks for watching my video, if you have any questions about this repair is done, please feel free to request clarification below.
Chris
Dec 26, 2009 | Hoover Windtunnel Turbo Power U4645-930...
How do I install the timing belt on my Hoover Savvy Vacuum? Modle # u8174-900 Where is it located?
http://www.vacshopusa.com/hoover_savvy.htm
This is a parts schematic for your hoover savvy. You have to take off the brush guard on the bottom and also the cover on top (there is a screw under the round hoover logo). You will then see how the belt is attached. Very easy to do. Hope this helps
Jul 02, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Trying to fix new belt to Hoover Turbo Power vacuum cleaner. Don't see how the belt becomes taut. Fitting it around the roller, there is nowhere to fit the belt to, it just sits loose.
I looked at the user instructions guide online and saw where the 'other end' of the belt should be fitted. It was extremely hard to fit but eventually managed it. Thanks for this solution site. I wouldn't hesitate to use it again.
Feb 17, 2009 | Hoover U5396-900 Turbo Power Vacuum
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
Jan 26, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Installing belt
here are the step by step instructions from the owners manual for your machine.
Disconnect cleaner from electrical outlet. WARNING: Agitator brush roll can start suddenly. Unplug cleaner before turning it over. Replacing Flat Belt Place handle in low position and turn cleaner over so bottom side is facing up. Remove the 6 screws as shown with a Phillips screwdriver. Lift off bottom plate. Replace belt if it is stretched, cut or broken. To check the flat belt. Removing Bottom Plate Removing Belt Positioning Belt Remove used belt from large pulley and discard. Reposition bottom plate and 6 Phillips head screws. Tighten screws securely. Insert agitator brush roll through belt and position belt in groove (A) on agitator brush roll. Inspecting V-Belt The V-belt is designed to last for a long time and is not normally replaced. However, if the V-belt is cracked, gouged or broken, it should be replaced. Slide flat belt off large pulley. To remove V-belt, slide back of belt over pulley (A). Then firmly pull on belt and “snap” it out. Discard used belt. To install new belt (with lettering on outside of belt), slide back of belt over pulley and pull front of belt toward groove next to pulley. Belt will “pop” into place. Flat Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for Flat belt - HOOVER part No. 40201-271. V-Belt: What to Buy Use only genuine HOOVER belts with your cleaner. When purchasing a new belt, ask for V belt - HOOVER part No. 40201-200.
If you can't get the answer from this post, send me a message and I will try to walk you through this. I hope it helps.
Jan 19, 2009 | Hoover Windtunnel Supreme U5280-900...
My girlfriend has a Hoover upright vacuum, Mdl. # U4645-930. I need a belt for the brush and a new bulb and am having trouble finding the correct part numbers so I can pick one up locally. Can you help?
I checked with Hoover and they said the part number for the belt is #38528040, for the bulb #27313101, and they also included a part number for something called an agitator #48414081. Not sure if this is required to replace one of the other parts. You might ask when ordering. To order, call 1-330-499-9499 or online at www.Hoover.com.
Dec 16, 2008 | Hoover Windtunnel Turbo Power U4645-930...
How to change belt on hoover turbo 4600
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=841267
Generic problem for all Vacuums
Posted by tbellme on July 27, 2008
How to change belt on Hoover Turbo 4600
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 27, 2008 | Vacuums
NEED TO REPLACE DRIVE BELT ON HOOVER VACUUM MODEL TURBO 3500
Apr 17, 2008 | Vacuums
Nov 18, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Elite U5061-900 Bagged Upright Vacuum Logo
392 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
