Question about Amana ALE331RAW Gas Dryer
Amana dryer does not run but i can hear the motor faintly
    Problem Solver:
  • 14 Answers
Sounds like the belt is either broken or slipped off the pulley. Remove the back of the dryer and find the motor. Look to see if the belt is still attached to the pulley. If not, look to see if it has slipped form the pulley and is hanging from the drum, or if it is broken. More than likely, regardless of which it is, you will just need to replace the belt.
Posted on Jun 04, 2009
2 Suggested Answers
SOURCE: Have AMANA dryer ALE230RAW. Hear buzz when start
I also have this problem, but it is after the dryer has been running. When the motor is hot, it buzzes and will not run. Sometimes it will run if I turn the drum or take some clothes out. I disassembled the dryer and cleaned the motor of lint. This helped but not completely solved the issue. I have completely removed the motor and will thoroughly clean the motor (stator and brushes) and will try again.
Posted on Jan 23, 2010
Simpson 4kg eziloader dryer wont turn on can hear faint noise when i switch it on though
If the faint noise is the motor running, the belt is broken.
Jan 03, 2014 | Dryers
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer just stopped working
not much to go on here, but if you hear anything that sounds like a motor running, then I would suspect a broken belt. There is a belt that actually runs around the drum that makes it turn. If you don't hear a motor running then you need to check your controls and cable(with a volt meter(just start at the motor and work your way back).If you hear a motor then its probably the belt that gos around the drum and motor( a little tricky to replace but not hard)
Jan 12, 2012 | Amana Dryers
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
Nov 23, 2009 | Amana Dryers
Amana Dryer 14 years old, turn on the dryer heats for about 10 minutes, then I hear noise like grinding noise and the heat turns off?
Remove the front panel and check the blower wheel on the motor. If it turns freely on the motor shaft replace it.
Aug 30, 2009 | Amana Dryers
Amana gas dryer wont start. just makes a faint buzzing noise
The drive motor starting capacitor is likely dead. This can be tested if you are competent enough to take the thing apart and use an electronic multimeter. Otherwise it is a cheap part to replace, depending on how much the repair guy charges for labor and to be called out.
Mar 18, 2009 | Amana NDG5800 Gas Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Amana ALE331RAW Gas Dryer Logo
271 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
