Question about Brother HL-2070N Laser Printer
Extra paper being fed after print job
I have a Brother HL-5170DN that will feed the whole tray of paper after a print job. How do I stop that?
Try a test page from the control panel, if this works properly you probably have an issue with the software of the printer. Reload the printer as if it was a brand new machine.
Posted on Jun 04, 2009
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
Brother printer will not print because I keep getting manual feed
thios means the job you sent to print was detected as a differant size then the paper in the tray.
you would have to put a page in the front slot of the machine until it clears out this job
Mar 24, 2010 | Brother HL-4050CDN Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Brother HL-5240 printer problem
This usually means a print job is stuck in the queue that was set to "manual feed" or to a different paper size, such as legal. Add paper to the front manual feed and press "Go". If this is the problem, the stuck document will begin printing from the manual tray.
To clear the problem without printing from the manual feed, cancel all jobs on the printer, delete any jobs out of the Windows print queue and restart the computer.
Dec 04, 2008 | Brother HL-5240 Laser Printer
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
Brother HL-2070N Laser Printer Logo
109 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
