Question about Mustek MDC-6500Z Digital Camera
Automatically powers down
When camers is turned on an error comes on the display that reads "Lens process to stop. Powering off!" Any help or direction would be appreciated.
Specialk
  • Anonymous Jan 20, 2009
    Does anyone have a clue as to whats wrong with the camera?
My camera blinks off and on.
Posted on Feb 28, 2008
Fuji finepix
When a camera notice the lens does not move, it is afraid to damage gears or the motor, of it powers down everything involved the lens. It then gives a message as you read.
Because the camera can't know what is casing this, it only can warn.
It "hopes" if it did run the lens to an obstruction, powering it down will relieve the tension. That is way it says power down.
Remove the battery, check the lens barrel if any obstruction is limiting the free movement of the lens. and then replace the battery. switch it on again.
If you accidentally touched the lens, while it was coming out, it could have given the same error. When after switching on the camera, and you are sure you don't obstruct the free movement of the lens barrel, but it comes back with the same error, you should contact a certified repair centre for your camera.
Jul 20, 2014 | Fujifilm Finepix S2980
How to fix Powershot Elph 530S so that the lens retract all the way when powering off
From the way you describe the problem it appears that the retraction mechanism has become out of line. I think that as you can hear a clicking sound the mechanism is working but not engaging with the lens. Try gently applying slight pressure on the front of the lens this may help to re-engage. You may need to consider a trip to the repair shop.
Jul 11, 2014 | Canon PowerShot Cameras
What is scanner error 22?
resolve by turning off by power switch, wait at least 30 seconds, then turn back on and wait for it to initialize. perform a hard reset on it. turn it off. press and hold down cancel and start copy buttons at the same time while powering on printer. continue to hold down until the control panel display reads PERMANENT STORAGE UNIT. RELEASE BUTTONS. printer should return to ready automatically
May 12, 2014 | HP LaserJet M1120 MFP All-In-One Printer
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
I bought canon sx30is from us two mnths back now problem has occured in my camera wen i start it gives lens error &shut down msg on camera comes lens eror camers shut down automatically restart...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
Sep 12, 2011 | Canon PowerShot SX30 IS Digital Camera
Washer fault code 3E what does it mean
during washing and rinsing when a motor restriction is sensed, the motor stops and then proceeds
to the next waterflow action. if the motor stops working and this happens in one direction 10 times,
the error code 3e will be displayed.you should be able to clear the error code by turning your washer
off and on. or powering it down and then powering it back up. good luck!
Feb 21, 2011 | Samsung Washing Machines
Lens error
The same thing happened to my camera, searching on the net for an answer and i found this. Strange, but it worked. Set your camera on a flat surface with the lens facing up. Tap it a few times and try again. Sounds silly but it worked!
Dec 09, 2008 | Canon PowerShot SD1000 Digital Camera
Kodak p850 Help!! error code
also having same problem after 18 months of no problems. As well, camera will not read memory cards which I have used in this camera almost since new. Format card, still no read. Sometimes when I take first photo, lens retracts as though camera is powering off but then changes it's mind and is o.k.
Jan 09, 2008 | Kodak EasyShare P850 Digital Camera
Faulty zoom mechanism
Your lens will need to be disassembled, and most likely replaced.  If the lens housing inside is not broken, it can possibly be repaired.  Otherwise, the lens assembly will need to be replaced.
Oct 11, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Mustek MDC-6500Z Digital Camera Logo
Top Mustek Cameras Experts
Mohamed Ismail
Mohamed Ismail
Steven Wander
Steven Wander
Are you a Mustek Camera Expert? Answer questions, earn points and help others
