Question about Nintendo Super Scope 6 for Super
SNES scope! only registers once on the first target & not 2nd
Problems with my SNES scope! When powered on, asks me to set the aim and then shows the first target. The scope fires when i pess the button and hits the first target however when it asks me to confirm/adjust my aim by shooting at the second target when i press fire nothing happens no matter how many times i press fire??
Tried swapping the port connections from 1 to 2 and back again but nothing registers on the second target......any suggestions?
2 Suggested Answers
  • 63 Answers
SOURCE: Hi,
make sure you're aiming at the center of the screen during adjust aim. also, try rapidly tapping the fire button.
Posted on Jun 30, 2010
Sighting in. bore was set up at 100 yds.My bc 120 drop .045. I only have a shooting range of 100 yds. Do i zero my shots in at 100
Yes you do and if you shots are only off by .045 inches low of target, you have no problems. Once you are zeroed at 100 yards, you need a real world range where you can test 200 yards. Aim using the scope at 100 and whatever the drop is, you compensate on the vertical reticule in the sight. Or you use your clicks to raise the point of impact.
Feb 01, 2018 | Optics
Sighting my rifle scope
Mount scope on rifle with the eye relief you are happy with
set up a target at 10 yards and fire 5 rounds of until you are grouping tightly ( no fliers ) you may want to use quite a few targets once you are happy with the grouping remove the adjustment covers on the scope
the top one is for moving the point of impact up or down
the side one is for left or right
depending on the point of impact you need to move it up or down to meet the cross hare once you get the point of impact on the same hight line as the aim point you can move the side adjuster to move the poi to meet the aim point
then move the target out to 20 yards and repeat the above again
then move the target out to a distance that you can put 90% of your shots inside 40mm or better and that is your max range for live animals
Dec 15, 2017 | Remington Optics
Does the aiming point have a lot of dots
Are you asking about the reticle style? A MilDot reticle will have several dots to use as aiming points at different distances. This scope provides for 38 different aiming points based on the distance to the target (holdover). It selects the appropriate one based on the internal rangefinder and the ballistic information you input for the cartridge you are using.
Jun 15, 2014 | Burris Eliminator Laserscope
Have nintendo scope 6 and able to do first screen but when it goes to test aim screen nothing happens just remains on screen
If the screen you see is a blue screen with a white target, you need to aim the Super Scope at the target, and shoot. This tells the interface box (the device you plugged into the SNES) where the center of the screen is relative to the Super Scope. If shooting the screen does nothing (does not continue the calibration routine by going to the aim test), your particular cartridge of Super Scope 6 is glitched.
Jun 25, 2011 | Nintendo Super Scope 6 for Super
I have an omark 44 drilled and tapped for scope have fitted a nighteater 8-32x44FC scope which runs out of elevation adjustment at 600 meters target,i want to shoot to 800 meters target,what can i do.
all you can do to raze the point of aim is to jack up the eye end of the scope with 35mm film strips or some thin shims,,,three strips of film will pick up the point of aim by miles
Nov 30, 2010 | Weaver 1" Rifle Scope Mount Rings 49719...
How do i sight this scope in, say for 100 yds what are all the sighting knobs for...?
You sight it in by firing at a target. Place the target at 100 yds distance if that is where you want it set for. Then you use the knobs to adjust the aiming point so the bullets strike where you place the crosshairs. This can involve a lot of shooting, and it is best to use a bench so you don't get confused by inaccurate handheld shots. Once sighted in, there may be other knobs to adjust for different distances or windage. These should be set to a central or neutral position while doing the initial siting, or maybe set to the distance you are siting in. My sights don't have such luxuries, so I am not sure how they work.
Oct 20, 2010 | Barska Optics BARSKA 156X42 IR Huntmaster...
How to use the BDC on my rifle scope
  1. Step 1 Take a rifle with a properly installed BDC bullet drop compensating reticle to a rifle range. Using ear protection zero the scope reticle so that the point of impact corresponds to the center of the cross hairs at the distance you have selected - typically 100 or 200 yds.
  2. Step 2 Determine the trajectory of the specific cartridge you have selected. There are several ways to do this. Ammo manufacturers publish trajectory and wind drift information. There are web based ballistic calculators like http://www.biggameinfo.com/BalCalc.aspx which will tell you how much your bullet drops at known distances.
  3. Step 3 Scope manufacturers like Leupold can be a valuable source of information about their reticle: "Leupold® Ballistic Aiming System: Boone and Crockett Club® Big Game Reticle aiming system provides a series of additional aiming points to improve your ability to shoot accurately at longer ranges. Nikon2_bing.gif also provides good information suggesting the marks on their reticle be used for zero at 100yds followed by circles below representing 200, 300, 400 and 500 yds if the cartridge travels around 2800 ft per sec. Nikon suggests the center cross hair be zeroed at 200 yds for magnum calibers traveling around 3000 ft per sec. We understant that each variation of different bullet weight and powder charge changes trajectory and a scope manufacturer can not build a different reticle for each different cartridge made so practice on the range to determine how well the marks relate to the actual impact of where your bullet strikes at a know distance is important. The one thing that people using BDC scopes typically have problems with is that a BDC scope has the reticle in the second focal plane of the scope. If the reticle was in the first focal plane of the scope the reticle would look smaller on low powers like 3x and grow proportionately larger as the power increased to say 9x top power. The problem is that while the marks on the BDC reticle correspond accurately to the bullet drop at the know distances 200, 300yds etc. What happens when you lower the power from the scopes maximum power to any other lower power is the reticle stays the same size and the field of view within the scope increases which means that the distance between these marks on the BDC reticle no longer corresponds to the point where the bullet will strike. In short BDC reticles only work at the maximum power of the scope or at a set specific power. At all other powers these BDC reticles do not accurately represent where the bullet will strike.
  4. Step 4 The center X always remains the same. If you zero at 100 yards and you know that your bullet drops 8 inches at 300 yards you could forget about the BDC marks and hold the center X 8 inches high - that works at any power 3x or 9x and should be used at lower powers. If you zero the center crosshair at 100yds and have the BDC scope at the maximum power 9X then the first line or circle below the center X should be the mark you place on the center of the 200 yard target----- the bullet strike should hit the center. If by some chance you put the scope on 3x and placed that first mark below the center cross hair on that 200 yard target you would shoot over the top of the target. This is because as the power of the scope decreases the field of view increases the angle increase and gets wider. You can experiment with known power settings and see at a specific power say 3x what that first circle down corresponds to and make notes because at any set power what the marks correspond to will be repeatable.
I got this from a website, hope it helps.
Apr 08, 2010 | Hammers Air Gun Rifle Scope 3-7x20 With...
How do you set a center point scope
the way i tell the guys to set there scopes up is this,,,first clamp the gun in a gun vice, fit scope or in your case a center point,,,aim at the target down the barrel then fire the rifle at target card,,,(a big one) at no more than 20yds away, look for the strike mark,,,and without moving the gun at all, after firing the first round, move the scope so that the cross or center point is over the hole in the target,,,then repeat this lot again till you have the bullet hitting were you point the cross, all you need to do then is move the target back and lower thee point of aim on the scope as it should be shooting at the moon
Nov 10, 2009 | Crosman Optics
How to set my bushnell scope 3-9x40 for 200 yards
The Bushnell 3-9X40 has been around for quite some time in several forms, but it is pretty standard to set it like any other scope.
With the gun resting solidly on sand bags or something like a Lead Sled, shoot at a target with a 1" grid on it. Those targets are a free download at http://targetz.com/, but you have to browse to find them. Targets No: 10049 or 10058 are both usable, if you can see a 1" aiming point with a 9 power scope at 200 yards.
With a known point of impact (POI) at 200 yards, you can move the POI to where you want it (inside the caps at the center of the scope, there are adjusting screws or slots). The norm is 1/4" per click (the adjuster can usually be felt to click) at 100 yards or four 1/4" clicks for an inch. At 200 yards, the adjustment will be twice what it is at 100 yards or 1/2" per click.
Make your adjustments, using the grid on the target to tell you how many inches it needs to move, and shoot the target again to confirm the adjustment is correct. It's pretty standard to shoot at least a three shot group to ensure the bullets are reasonably close to each other.
Another method is to set the POI at a certain number of inches high at 100 yards and assume it's right at 200 yards. If the mid range trajectory, for your cartridge, at 200 yards is X inches high at 100 yards, you can set your POI to that X inches high and be pretty close at 200 yards.
Nov 07, 2009 | Bushnell Trophy 3-9x40 Rifle Scope, Matte...
Can not seem to focus when we look through the lens we just see the bk=lack sky we cannot seem to see anything
try this:
see the mini scope on top of the telescope?--that's called the finder scope--
you look through that to see what the telescope is aimed at, just like what a sniper does before he pulls the trigger.
put in the lowest power eyepiece you have in the telescope, the one with a high number on it.
it's a good idea to align the 'finder' with the telescope during the day time--it's much easier.
if your telescope and finder scope aren't aligned properly, aiming your telescope at any target will be off and you'll just get frustrated.
to do this, look through your finder scope and pick a far away target, put in the lowest power eyepiece you have, that's the one with a high number--
high number = low power = a nice big view in the telescope.
low number on eyepiece = high magnification, like a zoom lens.
always use the lowest eyepiece first, then work your way to higher magnification, if you want to get a closer look at your target.
use lowest power eyepiece in telescope--> look through finder scope -->focus the image--> switch to higher power of eyepiece for a closer look at your target.
practice this during the day until you're comfortable, then try it at night.
try the moon, it's a nice big target
you can also use binoculars to check out the night sky.
you can try using 7x35 or 7x50 binoculars.
you see a lot more stars and it gives nice big views of the stars and constellations...and the moon...
hope this helps :D
Jul 30, 2009 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Nintendo Super Scope 6 for Super   Logo
117 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
