Question about Canon i475 InkJet Printer
I purchased a used Canon i475D printer purchased 2 new print cartriges and it will not print. It seems to go through the motions but no ink flow... I did remove the tape covering the print cartrige hole
SOURCE: Canon MP600 error code U043
6A00
Posted on Jun 15, 2009
komguy
  • 2306 Answers
SOURCE: my canon pixma ip2600 won't read the refilled ink
You can't reset the printer for a defective cartridge, you either need a new chip or a chip ressetter to reset the cartridge.
Posted on Jan 25, 2010
SOURCE: hello,i want to ask-how reset canon mp 490 ink
I tried pressing the OK button for 6 seconds, while holding it press the red stop button and hold it until the LCD refreshes.
Posted on Apr 14, 2010
  • 93 Answers
SOURCE: I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Posted on Jun 20, 2010
  • 5380 Answers
SOURCE: Where is the ink cartrige in Canon MP240 located
The cartridges are under the scanner and stay off to the right side of the unit except when printing or when you lift the scanner unit cover while the unit on. If the cartridges returns to the right, close the scanner unit cover and then reopen it. If the cartridge carrier doesn't move, make sure that the unit is turned on.
The black ink goes on the right side.
I hope this helps.
(if the cartridge holder doesn't move when the unit is on, check that nothing is blocking the path.)
Posted on Aug 02, 2010
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
Jan 19, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Will not print in black.
1st clean heads, on printers menu, then check if you have instaled non canon ink cartridges, you maybe burn out ink printheads. ONLY USE ORIGINAL INK CARTRIGES ALWAYS.this a normal failure on NON CANON INK SPARES.
Nov 22, 2009 | Canon Office Equipment & Supplies
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
Canon i960 qill not put ink on paper
I called Canon. I also had green 1 flash and amber 1flash everytime I turned on the printer. That right there indicates an elecrical problem. The flashes mean it needs serviced and with it not printing now means it's not wirth fixing, out of warranty. Canon did offer a code for reduced price new or referbished print from them.
May 27, 2009 | Canon MultiPASS F60 All-In-One InkJet...
I475d failing to print
uninstal the driver and reinstal it , recalibrate the printer.
Jan 16, 2009 | Canon i475 InkJet Printer
Canon i475 InkJet Printer Logo
24 people viewed this question
old marine
old marine
