Question about Whirlpool RMC275PD Microwave Oven
Need to know how to remove the control panel to check the fuse. Will not run, push start, beeps three times and light is not working. Please help us!
    Novelist:
  • 103 Answers
The fuses for microwaves are not normally placed on the control panel...they are in the back near the power cord...but the fact that it beeps 3 times means the fuse is ok...power is going in....most likely, the fault is one or more of the door interlock switches which arc every time you open and close the door and they corrode or wear down very badly sometimes even burn away so that there is no more contacts to come together....interlocks are cheap to buy and they just snap in place....access to them is easy...just remove the cover and look right behind where the door closes on the inside, you'll see a plastic bar on the door that when you close the door...it pushes on the interlock switches on the inside to activate the oven.......if the interlocks are ok...then you probably have a shorted magnetron....very common on any type of microwaves are these 2 parts...( the interlock switches and /or magnetrons.....it's not likely that your control panel is bad unless you physically see that something has burned on it.....good luck
silvio
Posted on Jun 03, 2009
Roper microwave /hood has stop completly working model # MHE14XMG1
The magnetron can overheat if the internal cooling fan fails, when you run it empty, when you run it a long time, or when you cook low-moisture foods like popcorn, bacon, or baked potatoes.
When the magnetron overheats past a certain point, its thermal protection device will kill power to the whole unit.
If the protection device is a thermal cutout, it will need a new thermal cutout.
If the protection device is a thermostat, it should reset after the oven cools down. If not, it will need a new thermostat.
You or someone you know can check this.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components. I've attached a marked excerpt.
In this model, the other parts which can commonly fail and render the oven "dead" are the 20A line fuse, and one of the cavity thermostats.
You can order parts from the Pros here. Just enter your full model number to do a lookup.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 05, 2017 | Microwave Ovens
Was working fine, punched in time to cook, hit start ...it ran for a second and then just went dead. No light, no display Microwave is 10 years old but never had a problem before
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 11, 2011 | Whirlpool MH7140XF Microwave Oven
It is behaving as if there is no power to the plug. There ias power i checked it.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should start working again
Feb 10, 2011 | GE JE1860 Microwave Oven
Model # jvm1340aw003 I think it has blown a fuse? Where do I find the appliance fuse in the microwave? My email address: claffertysr@sbcglobal.net Thank you in advance for your help, Mike
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and plug microwave back in. control panel should light up.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE MICROWAVE MODEL JVM1750DM1WW NO POWER AT ALL. HAVE ALREADY CHECKED THE OUTLET AND CHECKED THE BREAKER. ABSOLUTELY NOTHING WORKING.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. replace fuse and microwave should begin working.
Feb 09, 2011 | Microwave Ovens
Microwave will not start when time is entered and start is pushed
You got it! One of the door switches is not activating. Take a look at the door itself first. There should be two tabs that stick out. These tabs will engage in the holes near the control panel. If the door does not have a broken tab then the problem is behind the control panel on one of the switches. There are 3 switches back there.
Unplug the power cord, it is usually in the cabinet above the microwave oven. Then take the grille off the top, the screws for the grille are on the top of the unit facing down. With the grill off you will see the one screw on top of the control panel, remove that screw and lift up and out on the control panel this will give you access to view the switches and test them with an ohmmeter.
May 02, 2010 | Kenmore 60654 Microwave Oven
The display works (clock, mode, etc) I can push
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
Apr 27, 2010 | Whirlpool GH9176XM Microwave Oven
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
370 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
