Question about SanDisk Sansa e250 MP3 Player
I had 450songs in my mp3 and they all work. iput more song inand now none of them work. when i push play the mp3 say TRACK IS BAD.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Dell DJ 30 gig is stuck on recovery mode. Already tried pin hole reset. I don't mind wiping all the music of I just want it to work again
Assuming you simply pushed the reset, you will get only a reboot back to whatever problem you already had. If you hold the play/pause button while briefly pushing the reset, it should boot to the recovery screen. Then try selecting cleanup, then reboot after it finishes.
If its now ok, then great. If not, then do the hold play and reset again, this time selecting format. This WILL wipe all your songs, but may just let it work again afterwards. Worth a try....
Apr 29, 2009 | Dell DJ MP3 Player
Songs will not play....
I have same model but no problems. had older model w/ same issues. try holding menu button and center button at same time for about ten to twenty seconds to reboot. that might clear up the bug.
Mar 10, 2009 | Apple iPod MA446LL/A MP3 Player
My zvue spirit mp3 player is skipping through songs
the song could be a wrong format for your zVne mp3 player, you need to change the song format so that it will be playbale on the zvne, use audio converter to convert the song format, check detail in the link
Nov 19, 2008 | Zvue Spirit MP3 Player
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
My sansa e250 mp3 wontt play songs.
try to format your mp3 using the cd included in the package if there is any... if none, google for the software of your pc and format it using the software...
Aug 26, 2008 | SanDisk Sansa e250 MP3 Player
My mp3 player is frozen
Plug it in to the computer with the USB cable, use a paperclip to push the reset button inside the top hole, and then press the power button.
Feb 26, 2008 | Memorex MMP8565 MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
10sec play
try reseting it. then resyncing your ipod. to reset it, simply push the middle button down, and the menu button at the same time. a few seconds later and the ipod should reset. then sync the song that had the problem onto the ipod and see if it works. (no point in syncing all your songs becuase if reseting it doesnt work you wasted alot of time syncing songs for nothing)
best of luck : )
Jan 22, 2008 | Apple iPod nano
Selected songs won't play
What happened after you restored the iPod? Did you transfer the songs again and again, they didn't work? If so, your hard drive is probably defective, have you heard it making clicking noises?
Dec 24, 2007 | Apple iPod MA446LL/A MP3 Player
Mp3 player won't play
your ILO has somehow lost its file structure. look for a tiny pinhole to reset the device. if none, then remove batteries to attempt reset. if still no songs, then firmware upgrade if possible or copy file structure (using windows) from a friend's ILO.
Jun 08, 2007 | iLO (2 GB) MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
