Question about Hampton Bay 13087 70450 Carousel II Ceiling Fan
I have a Hampton Bay 129857 fan can you tell me the color schematic for the wires that go from the speed box to the speed switch. I have orange, yellow, purple and black wires.
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
we have a hampton bay fan burning smell coming in didnot run
Posted on Jul 07, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 37 Answers
SOURCE: Bay Model # 526-012 Fans what size speed control
I can't see any reason why a Leviton fan speed control couldn't be used on any ceiling fan, after all, I don't even think Leviton makes ceiling fans. Second, you may be able to try using the 1.5 amp fan speed control and see if you can get by. The worst that could happen is the speed control wouldn't work or would only work for a short time and be junk.
Posted on Jan 24, 2009
toolkits
  • 1099 Answers
SOURCE: My Hampton Bay runs too slow on high speed and makes slight hum.
hello,
the fan could have a weak coil that is ability to run fast or the capacitor is leaky, if found to be bad replace with a new one of the same rating..
Hope this will help...
Posted on May 31, 2010
I need the wiring schematic for a Hampton Bay 52' ceiling fan with lights, has 2 pull switches and a slide switch.
You should have 5 wires to connect. Green is ground and it may also be a bare copper wire, White is neutral, black and the other are hot, they control the fan and the other controls the light. IF you are hooking them into a conduit box that has white black and ground (which is bare) you hook the grounds together and then hook the whites together and then the other two from the fan connect to the black wire in the box.
Jun 16, 2015 | Hampton Bay Dryers
Westinghouse 3speed fan switch 77288
It's the westinghouse switch. Many results on search. I just wasted 2 hours playing switching wires all combos. Others suggested the switch from Lowe's. Harbor breeze #0033905 . Plug wires back in as you listed Black L, Grey 1, Brown 2, Purple 3. Works perfectly for $3.98 plus tax.
Others said you can call Hampton Bay and get the replacement also.
Sep 24, 2013 | Hampton Bay Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Jul 23, 2008 | Hunter 23852 Classic Original Ceiling Fan
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Hampton bay ceiling fan
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Jan 28, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 13087 70450 Carousel II Ceiling Fan Logo
95 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
