Question about Tivo Series2 TCD649080 Video Recorder
How do a hook up a hdmi cable to my laptop and than display my laptop screen on a tv?
I have a Dish hd set and on the side of the t.v i put in the Hdmi cable to the Hdmi 3, but when i switch to that channel it comes out static and nothing appears....what should i do??
Posted on Jun 08, 2009
What's your problem?can not hook up lap top to tv
Connecting your laptop to your TV will require a HDMI cable. Attach the cable to the HDMI ports on the latop and TV, then change the source input from your TV to HDMI and your TV will now display your laptop.
Jan 30, 2012 | Televison & Video
When i hook up a hdmi cable from my lap top to my tv it rotates the screen to the left
Have you tried changing the orientation from potrait to landscape or vice versa in the Display Properties Window(Right-click Desktop-Select Display Properties)? Should be in there somewhere.
Jan 11, 2012 | Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
HP Pavillion 500series to Panasonic TV with DMI port, hooked the HDMI cable from it to the tv, blank screen, made sure the tv was on HDMI, blank screen, unhooked the monitor, blank screen, hooked the...
Most laptops have a "toggle":
* output video only to internal LCD screen,
* output video only to external HDMI port,
* output video to both internal & external.
Set the "toggle" to the best value.
Jun 15, 2011 | HP Pavilion dv9000z Notebook
I want to connect my dell inspiron 1525 to my lcd hd ready tv but have no idea how to? Does anyone have any advice?
The 1525has a a hdmi port which you can plug a hdmi cord into. This may not support the audio. the tv and pc should detect the new monitor automatically or you may have to toggle it by hitting F4 key.
Apr 22, 2011 | Dell Computers & Internet
I have my laptop hooked up to my Sony LCDTV (using it as a big screen) via HDMI cable, but now the laptop screen doesn't work. I disconnected the HDMI cable and restarted the laptop but the screen comes up...
Go into your display driver, and make certain you have it set to have the internal LCD as your primary display. There should be an option to go ahead and have it either act as a second display just cloning what's on your screen or to have it extend. (select the option to clone)
Oct 03, 2010 | LG LW20-EV Notebook
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
Hooking up my hp laptop to a sony trinitron tv
Let me explain on how to connect the TV to HP notebook.
There are two ways to connect the TV to the notebook. One is with the S-Video cable and another one is HDMI cable. (If you computer had HDMI port)
Connecting notebook and TV with S-video cable:
You need to get the Svideo cable and connect it to the notebook Svideo port to TV Svideo port and press Fn+ F4 to get the notebook display on the TV.
For the first time pressing the Fn+F4 keys, you will get the display on the TV and there will be no display on the Notebook.
If you press the Fn+F4 for second time, you will get display back to the notebook and Tv screen becomes blank.
By pressing the same keys again will show the display on both the screen.
Samething connecting with the HDMI cable, if your computer had HDMI port.
If you won't get the display on the external screen even after following the correct process, then once you need to reinstall the display driver.
If the issue persists, then you have to check with another cable.
Note: No need to install any software on the notebook to connect the TV to the notebook.
Aug 01, 2008 | HP Pavilion dv6000z Notebook
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Tivo Series2  TCD649080 Video Recorder Logo
183 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
