Question about Kenmore Refrigerators
Kenmore fridge not making ice
Ice maker is not making ice
Did everything- pulled on ejector bar, defrosted refrigeretor, no ice- will call Sears repair service
Posted on Jun 04, 2009
SOURCE: Kenmore ice maker
If the ice ejector (the plastic part) is pointed down and not pointed between 10 and 3 o' clock the ice maker motor has failed or somethin is binding. Replacing the ice maker is probably the best bet.
Posted on Aug 14, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
Kenmore fridge model 596 - 79213014 2 yrs old accumulates ice at the bottom freezer. The fridge has built it ice maker but we did not opt for that option. Can anyone pls advise how tofix the problem?
IS THERE A CONTAINER FOR THE ICE TO COLLECT IN UNDER THE ICEMAKER??? IF NOT YOU WILL NEED TO GET OR ORDER ONE..
NEXT THERE IS A WIRE LEVER ON THE RIGHT SIDE OF THE ICE MAKER. WHEN THE ICE PUSHED THAT LEVER UP IT WILL QUIT MAKING ICE. WITH YOUR HAND GENTLY LIFT THE LEVER UP UNTIL IT STAYS LOCKED IN THE UP POSITION... ONCE IT IS IN THE UP POSITION ... IT WILL NOT PRODUCE ANY ICE.
Dec 29, 2014 | Kenmore Refrigerators
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
Connect ice maker
Almost all ice makers have a plug on them and the fridge has a corresponding plug. If you cannot find the plug in the Fridge - look in the area of the ice maker for a plastic plug in the wall of the fridge. If you've added this to the fridge after the fact then you may need to fish out the plug from the wall of the fridge.
Aug 06, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore model 46 76249 (22 CU F OVR
Freezer must be 12* F for making ice
May 13, 2009 | Kenmore Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Mar 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge: not making ice, no water in ice maker
look to the water inlet valve behind refrig sound like you got a frozen line, or a bad solenoid
Feb 19, 2008 | Refrigerators
Kenmore ice maker
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
136 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
