Screen turned red
My TV screen is red and a tried to adjust it but nothing works please i am begging you tell me how to fix this with out having to have a repair man come
  • 1694 Answers
SOURCE: No power to TV
Make,model,month & yr built (off sticker on back of set) ??
Also,clarify symptom??
Changed fuse-was it bad??
Posted on Oct 24, 2007
  • 1694 Answers
SOURCE: Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Posted on Oct 25, 2007
  • 346 Answers
SOURCE: TV Screen Vertical
you need a qualified tv technician to solve this problem. the vertical ic has to be changed
Posted on Nov 16, 2008
SOURCE: TV won't turn on, red light flashes twice
Fortunately, Sony, of all manufacturers, has built in a diagnostic tool to help you decide what the problem is.
Below is a text on these codes. This is not your model, but the basic diagnosis remains the same. You can count the number of blinks and then look up the problem and solution below:
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If the timer/standby indicator is blinking, this could be an indication of the problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks (depending on the fault) about a third of a second apart, then pauses for 3 seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those which you will see for each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
As a general rule, the blinking standby light means serious problems and you would be better off getting a technician involved.
This set is a very expensive one and it has some life left in it. Further it is a Sony, so you will be wise to get it fixed.
After studying the blinking codes, let me know if you have any further questions.
Have a great Holiday Season,
Cleggsan
Posted on Jun 28, 2009
  • 12 Answers
SOURCE: my zenith b25a10z tv has no color...can it be fixed?
main ic is bad, as I remember it starts with TA
Posted on Jul 08, 2009
How,do I fix ps3 red screen because nothing works I tried everything even safe mode
Please describe the problem in more detail. Is the screen always red from the moment you turn it on? Are you connected to your TV via an HDMI cable or standard VGA? How long have you had this problem?
Dec 24, 2014 | Sony Playstation 3 (PS3) Console
Chicony webcam usb 2.0 PLEASE HELP (TOSHIBA)
Honestly speaking, the cost for USB webcams is so low (around $15 to $25) it is not worth the hassle. Just get a new camera and do not get upset with the one you have as fixing them is not worth the cost.
Mar 10, 2014 | Toshiba Satellite A135-S2276 Notebook
Philips hd tv monitor 51pp9303h/17 dp TV 345 347he10839 TV receiver 3135020592 my screen is red and I tried to adjust the color nothing happen it still red can I fix myself
The model indicated is a older rear projection set.
If you go to a program that is black and white and turn the color off the screen should be something close to black and white.
There is a way to adjust the red screen down but it takes two people.
If you want to know how and what is involved let me know.
SD TECH
Jan 17, 2012 | Philips Televison & Video
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
I have to much red in my picture
Hi
First check whether all the cables from your dishnetwork are fine and connected firmly.If yes then you'll need to pull off the front of the tv, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. so we are doing real small adjustments. Turn the color off on the tv and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittant red picture tube, a bad red driver transistor on the CRT board, a bad connection on the blue crt board, or a problem in the RGB coming from the video jungle IC. This TV set most likely will run you about 200 to 400 bucks to have this problem fixed, unless it is the picture tube.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 13, 2009 | Philips 42PF9631D 42 in. Plasma Television
BLUE SCREEN
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Sep 25, 2007 | Sony KP-57WS500 57" Rear Projection...
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Blue Halo, Tried to adjust on Projection TV
The convergence issue you have will not adjust out....repair
of the convergence circuit will be necessary....then adjust...T.
Dec 01, 2006 | GE 46GW947 46" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
