Question about Troy Garden
My weedeater is hard to pull and hard to start.
My weedeater is hard to pull and won't start. Is the problem the valve adjustment because the pull cord is in good shape .If the valves nedd adjustment ,how do I adjust them?
  • 15 Answers
SOURCE: need valve adjustment for a for a briggs and straton 31p777-0348-
Try .003-.005 on the intake, .005-.007 on the exhaust.
Posted on Apr 23, 2009
  • 246 Answers
SOURCE: weedeater pull cord will not return to original position
Hello mart656:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
SOURCE: Briggs and Stratton OHV V-Twin 24hp repetitive valve adjustment
Try pulling out the choke a little, if it stops backfiring the mixture is too lean, check the intake
pipes at the cyl head and also the plastic runners to the carb for leaks.
Dennis in Chicago
Posted on May 15, 2009
SOURCE: broken pull cord
You have to take four allen screw out of the plastic that holds the engine on. There is also one by the spark plug that needs to come out. Once the engine is loose, you have to unplug one wire and unscrew the other. Then the engine should come off. Then loosen the two allen screws holding the pulley in and it will come out.
Posted on Jun 02, 2009
#1 Taper
  • 1040 Answers
SOURCE: Ryobi BC30 Weedeater - Cannot Start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Jun 21, 2009
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Won`t start, good gas, has new plug and good spark, new carb, clean air filter, plenty of oil?
check you have good compression. remove plug and cover hole with a bung( cork of rubber) .
there may be some debris keeping the inlet valve open .
try compressed air to blow out cylinder whilst turning engine over(pull the cord).
reinstall plug and it should fire.
Jul 07, 2015 | 5.5 HP GX160 Engine
Honda GC190 can't pull starter cord
This is a problem with GC-160 and GC-190 engines on pressure washers, tillers, etc. Once they get some hours on them and as things seat in-wear in, they get to a point you can not pull the start cord. If you remove the spark plug, the engine turns easily then the valves need adjusted. The valves are set .005" to .006" off the seat. This allows enough compression release but the engine runs. I find the valves need adjusted every 25 hours, not the 100 hours Honda states.
Aug 29, 2012 | Honda Garden
Yamaha R1 won't start after I adjusted the valves.
Hi, Jason for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.r6messagenet.com/forums/r6-maintenance-technical/982-remounted-motor-adjusted-valves-bike-wont-start.html
Yamaha R1 Valve Adjustment Compression Test
Yamaha YZF R1 Service Repair Workshop Manual 04 06 Download Manuals...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Apr 21, 2012 | 2000 Yamaha YZF-R1
When I try to start my gas-powered pressure washer, its very hard to pull the crank and I cannot start the motor.
When everything is working correctly, and your washer has an easy start valve, (easy start valve will allow you to start the machine with-out having to hold open the trigger) the engine should pull easily. Some washers do not have easy start and you must hold open the trigger on the wand to unload the pressure in the pump. If you are holding open the valve and still have difficulty, remove the water supply and pressure hose and let out all the water. If still hard to pull most likely something has failed or pump is low/out or lubricant. If lubricant is ok, try reducing the pressure adjustment to minimun and try starting. If it is now easy to pull, problem is related to pressure regulator /unloader valve. Try adding oil to water inlet and let the oil displace out all the water within the pump and let it set for a while. Good luck
Jun 17, 2011 | Garden
Water want cut off keeps running and filling up with water
Pressure sensing tube obstructed. Remove water from machine. Find the tubing and remove it from the water level switch so yall can blow it out. Reconnect the tubing and party on!
May 16, 2011 | Washing Machines
My mower (HRR) was hard to start and then would
It sounds like you are in need of a valve job on it. You can check this by removing the spark plug and holding a finger or thumb tightly over the hole while someone pulls the starter cord. If it doesn't literally "pop" your finger off the hole, you have a leaking valve and need to do a valve job or at the very least a valve adjustment
Oct 26, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Generator hard to start. Kick back
This sounds like the timing is off. Remove the spark plug and pull the cord to see if there is less tension. If there is less tension then you know that the pull cord is fine. Do a compression check on the cylinder, it should be around 100psi. Remove the valve cover and check to see if valves are moving when your pulling the cord. The valves could have came off the rockers.
May 19, 2009 | Electrical Supplies
Dennis in Chicago
May 07, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Blowing gas out the air intake
Eight years is great for a weedeater! Blowing out can mean something is stuck in the reed valves, or one may be broken. They are just under the carb, usually. Be real careful with the gaskets. If you mess up any, silicone will do. Use good car gasket silicone.
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Garden Logo
770 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
