Question about MSI MATX MB VIA P4M900 LGA775-VID SND PCIEX16 2PCI Motherboard
4gb ram installed only 2gb recognised-? win 7 64bit 3.25gb recognised with win 7 32bit ???
  • 55 Answers
Bcoz *********** supports maximum 2 GB...
Posted on Jun 20, 2009
My pc keeps hanging when i install an additional ram which is 4gb my current ram is 2gb My specs is: Intel Core i3 530 2.93GHz 2GB RAM 2GB Palit GeForce GT 610 1TB HDD Windows 8 Pro 64-bit Asus...
what clock speed is $are 2gb Cards. You should use 2 2gb cards rather than 4 1GB cards. If you can boot up down load Belarc Advisor and run identify particulars. It's free.
Sep 03, 2013 | Gateway Dx4831-01e Intel Core I3-530 2.93...
2*2GB (4GB) ddr2 shows up as 2*1GB ddr2 (2GB)
It could be a problem if you are running a 32 bit operating system. I know that there is a limit of around 2gb on any 32bit windows install. this can be fixed by installing a 64bit version, IF your hardware supports it. You would need a 64bit cpu to install 64bit windows. If this is not the reason you are having the problem, the only other reason that would make sense would be that your motherboard doesnt support more than 1gb of ram per DIMM hence it shows that two are insalled but can only use one gb each. This i think is the more logical answer because I think the limit on GB for win 32bit was more like 3gb. good luck
Oct 08, 2012 | Intel DG43NB Motherboard
I am buy ram 2gb bus 800 two pcs that was 4gb bus 800 in the two slot when I rest PC;show 3.xxx Total memory That most be Show 4.xxx . How I do?
This motherboard does support 4GB RAM, however, if you are running a 32bit OS, like XP, Vista 32 and Windows 7 32, you may only see 3.5GB as this is a limitation to 32bit. If you are running 64bit Vista or Windows 7 you will see the full 4GB.
Regards, Chris
May 13, 2011 | Gigabyte GA-945P-S3 Motherboard
Have an EVGA nForce 680i. Bought 2x 2 GB 6400 800Mhz of ram to replace 2x 1 GB sticks. However when I start up the system it only reads that I have 2874 MB of RAM. So I figured maybe one of the sticks is...
Hi.
The reason its only seeing just under 3GB of memory is no doubt because you are using a 32BIT operating system (probably XP).
If you were to install Win 7 (X32) or a 64BIT operating system the computer would see all 4GB of RAM you have installed.
Its nothing to worry about though as the computer will work just fine. If you were to check in the BIOS you would see all 4GB of memory is there and see by the BIOS.
Regards.
May 01, 2011 | Evga nForce 680i SLI (122CKNF68)...
When i install Bios up date for MSI KT6 Delta MS-6590 to up grade my RAM to 3 GB i have Problem m My PC go to hill too slowly but i have 2400+ CPU ???? how can i solve my problem
Ram need to be installed in pairs. Windows XP only recognizes a max of 4GB ram 3.5 usable. Windows Vista 32bit only recognizes a max of 4GB ram as well as Windows 7 32bit. Vista/7 64bit can recognise a much larger amount of ram. Find out if your operating system is 32 or 64 bit and make sure you are using the right kind of ram for your system.
Mar 13, 2011 | MSI Microstar KT6 Delta (MS-6590)...
It is just slow low ram and want to know if i can put 2 new 2gb in it
You can install up to 4GB of DDR2 RAM at speeds of 533mhz, 667mhz, and 800mhz into that motherboard according to the ACER website.
However, since the computer is operating, by the sounds of it, then you should go to http://www.crucial.com/
and click on Scan My Computer (it's will be a blue bar near the top of the page). It will scan your computer, tell you what RAM you have installed, what RAM you can install, how much you can install, and it will also show you links to RAM that you can buy for your computer. It is quite handy.
I hope this helps! If not, please comment back and let us know!
Jan 04, 2011 | Acer Aspire™ T180 PC Desktop
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
Ram Installation more than 3G ex: (4G or 5G) will read 3.25 G How? i am using 2 units of KVR800D2N6/2G pulse 1G original>
Probably your Operating System is a 32bit. 32bit OS can only read up to 3GB of RAM regardless of the capacity of RAM you install. For example you installed 2pcs of 2GB RAM, that makes it 4GB in total, 32bit OS will only recognize 3GB. upgrade your OS to a 64bit OS and you can upgrade your RAM up to 8GB depending on how much your motherboard can handle.
Sep 15, 2010 | Computers & Internet
My windows not shwoing whole RAM size
What you are seeing is correct. You have 4GB of physical RAM installed in the computer and it is being recognized properly by the BIOS. A 32-bit operating system can only address approximately 3.5GB of RAM. Vista may be rounding the number down to 3GB or if you are using on-board video, some of the RAM is being allocated for use by the video circuitry and is not reported as system memory. To see all of the installed RAM in your operaing system, you need to upgrade to a 64-bit version of Vista.
May 29, 2009 | Kingston 2GB Secure Digital Memory Card
EXTENDING EXIST 2Gb RAM to 4Gb
hai ,frist u go to
start--my computer(right click it)---manage---disk management---
see your new hard disk & right click and shirnk volume
Jul 13, 2008 | Toshiba Satellite P205-S6287 Notebook PC
MSI MATX MB VIA P4M900 LGA775-VID SND PCIEX16 2PCI Motherboard Logo
142 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
