Question about HP Pavilion dv6000z Notebook
Note book my dv 6000 note book monitor wont come on black screen
  • HP Master
  • 32,281 Answers
You most likely have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Jun 04, 2009
Benq v32-6000 power light stays on but no display on screen
if totally black screen it could be screen back light problem, if just a white screen it would be a bad lcd controller. by the way have you tried replacing with other monitor just to ensure if the problem is the monitor.
Sep 27, 2012 | Computers & Internet
Any idea what's wrong with my laptop? The screen went black and wont turn on anymore. Was using it yesterday when it suddenly went black. Took the battery out and put it back a few times but all the...
Is the laptop an HP DV 2000, 6000, or 9000 series? If so you could be one of the many afflicted with a problem that caused many HP laptops to go poof. There was an issue with these series of laptops motherboards causing the screen to go black, and then not power on. There was a recall that made the manufacturers warranty a year longer (from 1 to 2 years) but that has long since passed. Since it is the main board of the computer, it's a several hundred dollar repair and is typically more expensive to repair than it would be to buy a new laptop.
Regardless of whether or not this is your issue, I would recommend re-seating the RAM or having someone who is familiar with computers do this for you. Basically by removing and re-inserting the RAM in the computer you ensure there is a snug fit as this could cause a similar problem.
Mar 07, 2011 | HP Computers & Internet
Hp dv 6000 black screen problem
these is small hv board circuit, inside lcd is defective, needs to be replaced. send to repair.
Feb 09, 2010 | HP Pavilion dv6000z 15.4" Notebook Laptop...
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
HP Dv 6000 series Screen got blurr suddenly.
Restart the system holding down f11 key to run system restore to factory default setting. Remember to backup your documents
Rate this dear
May 28, 2009 | HP Pavilion dv6000z Notebook
Toshiba laptop satelite a135-s2386. I went to turn on computer and there is power but the screen is black. Thanks!
connect an external monitor on the unit and press the key combination to get the video on an  external monitor this is different on some laptops on HP dv 6000 for example it is FN F4 if external monitor work the problem is with your laptop display if the external monitor doesn't work its probebly your systemboard als check your memory.
May 04, 2009 | Computers & Internet
Lost screen
you need to find out if your screen is bad. does it sounds like it booting up and you hear the sound when windows boots up? you can also try connecting your laptop to an external monitor. if you see a display on your monitor, then you screen on the notebook will need to be replaced, if you dont see a display on the external monitor, then you have most likely a bad mainboard , you might have a bad ram module too. but most likely the main board
thank you
Apr 19, 2009 | HP Pavilion dv6000z Notebook
Screen black wont boot up
If it is new and under warranty. Use its warranty.
Apr 14, 2009 | Acer Aspire 5100 Notebook
I have a dell inspiron 6000 the screen goes black
the lcd screen may be causing this. Try to connect the laptop to an external monitor and have both working at the same time by toggling Fn F8 on the keyboard. Wait until it goes black on the LCD. post back what happens. If the external monitor wont go out when the lcd does, the lcd may have to be replaced. If the monitor goes out too, it's a video card issue which may be resolved by reinstalling the driver.
Jan 31, 2009 | Dell Inspiron 6000 Notebook
HP Pavilion dv6000z Notebook Logo
124 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
